Is my line in training?
Doorman
I've just re-joined plusnet (service went live about 6 days ago) and wondered if there's a way to check if my line is in training? I thought I would have seen some speed/sync variations and reboots in the router stats but the only changes I've seen is on the two occasions I had to do a forced reboot while having some teething problems with local network connections. Speeds are around 2mb slower than last time I was with plusnet so wondering if they will improve on there own
15 REPLIES 15
Fixes: 87
Re: Is my line in training?
I believe that the training time is 10 days. The important thing is not to reboot it during this time in case it's assumed to be a line limitation.
With the uptake of broadband use, especially streaming, in recent years crosstalk is increasing, adding to background noise on telephone lines. This causes a slow down in sync speed. Over the past few years I have lost 9Mbps from my fibre sync speed.
All you can do at the moment is give it time.
Is that the synch speed or the actual throughput that's reduced?  The training period won't generally improve the synch speed, but depending on what profile was applied in the first instance it's possible that either the BT profile or Plusnet's is applying a restriction.
Fixes: 282
Thanks for getting in touch @Doorman
As advised above your line's training period is 10 day and this starts from when the order is completed.
I've tested your line and I can see that your router is currently in sync with the exchange at a rate of 14.9Mbps which means you should be seeing download speeds around the 13mbps mark.
This is well within the estimates for your line of 7 to 12.5mbps at this moment in time. It may be that when you were with us previously your line was put on a 3db target which offers slightly faster speeds.
The DLM (Dynamic Line Management) software at the exchange may move you onto this after your training period is over but this ultimately depends on how well your line performs.
If there's anything else we can help with let us know
 Matthew Wheeler
Doorman
Thanks for the replies. It resynched at a higher speed, presumably when you tested it and a speed test result is now roughly what I would expect.  The only reason I posted is that the router stats suggested it hadn't resynched at all during line training apart from the two occasions I forced it to and I had expected to see it do it a few times.  All seems fine though.
Just one more thing. I'm using an old router (Plusnet branded 2704N)  and the firmware is showing as 7.275.2. Does this need updating?
Fixes: 282
Thanks for getting back to us @Doorman.
Generally speaking, your router should only resync during the training period if DLM wants to make any changes to your line.
Currently, your line quality is Amber which means as it stands DLM won't make any positive or negative changes.
With regards to the router firmware, it appears you're using an older version. This likely won't cause you any issues but I've asked the relevant team to push out an update.
Let us know if there's anything else we can help with
 Matthew Wheeler
Doorman
Thanks @MatthewWheeler
Any idea how long it will take for them to do the firmware update? Just checked and no change.
Fixes: 51
Hi @Doorman,
Looks like the products team have tried to push a new firmware down but the router isn't showing online in the tool to update. We've removed it from the account and re-added it. Can you please perform a full factory reset and let us know when you're back online so we can let them know to try again.
 Joe
Doorman
@JOLO
OK I can do that but before I do, can you tell me what login details I will need to use after the reset as I assume my current user chosen ones will no longer work. Is there a default username/password?
Fixes: 56
Hi @Doorman
The factory reset will change all of the logins back to the ones on the base/back of the router.
If the reset reverts your username and password back to default in the router's hub, you can update them by following the information I've raised on a ticket for you here.
Best wishes
Dave
 Dave G
Doorman
@RandallFlagg
Thanks for the info. Factory reset now completed so can you try again with the firmware upgrade now? Thanks.
Fixes: 53
Hi @Doorman
I've requested this to be done for you now
Thanks,
MoR
 MoR
Doorman
@MasterOfReality
Still no firmware update. Is there still a problem even after the factory reset?
Fixes: 51
Thanks for your post @Doorman.
I've just updated the task that we'd raised as I can see that the products team has asked us for further information.
We should receive an update within the next couple of days and will update you directly here as soon as we do.
 Owen P
Doorman
@OskarPapa
Just got home and looks like the router updated to newer firmware about 12 hours ago.  All seems to be working fine so thanks to all of you for the help.
