Is my connection banded?
- Is my connection banded?
- « Previous
- 1
- 2
- Next »
Re: Is my connection banded?
27-09-2009 9:14 AM
Quote from: grahamt It seems to be quite normal for banding to remain for much longer than three days, however stable your line is. Maybe you can get released after three days the first time you get banded, and then the interval increases thereafter.
Hi Grahamt,
I have never been banded before and its now day fourteen. The fact that I am paying for a product that a third party is restricting is the annoying part. The product is damaged enough by Plusnet's throttling and now we suffer with BT using a banding system they cant control. BT are using a flawed system and ISP's like Plusnet are letting them get away with it.
John B.
27-09-2009 4:22 PM
(Edit: I included that link to A&A before I saw that Oldjim had already quoted it in another thread. Great minds... not that mine's that great.)
However, with enough badgering from enough other ISPs, I'm pretty sure BT will improve their DLM software eventually. I suspect their own customers will complain loudly once they are moved to the 21CN in large numbers and see that they should be getting the 'up to 20mb/s' speeds touted in the BT ads.
Admittedly, until that happens, it's a pain.
Graham
27-09-2009 10:59 PM
Would the advised BT visit sort this. Or does the line get banded because of an underline line fault somewhere.
28-09-2009 10:31 AM
We have no control over which band is being applied nor do we have any control over whether or not it is turned on or off. We can ask for it to be switched off though.
John - Leave it with me and I'll see what I can do.
28-09-2009 10:36 AM
John B.
28-09-2009 10:55 AM
How do I get banding turned off then, I think I am being banded between 576-1152. I have a ticket outstanding from trial request and am being advised to get a BT visit to sort the line.
28-09-2009 11:05 AM
Banding has been turned off.
@amjrobson
We only remove banding in extenuating circumstances. Lenseman is a 'special' customer. You are currently on a 576K - 1M band, but this should be removed following a period of stability.
If it's still not removed after a week, then let us know and we can manually intervene.
28-09-2009 11:26 AM
Quote from: Jameseh Lenseman is a 'special' customer.
Roughly translated = Damned Nuisance!
Thanks James
28-09-2009 11:36 AM
Quote from: Jameseh
Thanks for the response, it has been connecting at 1152 since last monday, how long does it need to remain stable for before it will remove the band. Is it worth BT comming out to investigate a potential line issue then as being suggested on my support ticket. I dont want to have to pay BT costs if there is nothing wrong with the line except for the Banding.
28-09-2009 11:45 AM
Hang on - You seem to be syncing at 2670Kbps.
Has this just changed?
28-09-2009 11:50 AM
Yes you are correct, just checked my line and it resynced at 11:32am and is now at 2670 download.
Pehaps I spoke to soon and the Banding lifted automatically.
28-09-2009 11:59 AM
as you can see here james my banding got removed at last after many MONTHS of STABILTY.
28-09-2009 12:01 PM
I'm referring to ideal world situation. Ie: the product actually does what it's meant to.
29-09-2009 9:40 AM
My sync speed is nearly what it was before the problems in June.
On the BT test it is saying my profile should be 6000kbps so just got to wait for my Plusnet profile to catch up (hopefully before BT screw it up again).
John B.
- « Previous
- 1
- 2
- Next »
