Is it possible?
- Is it possible?
Re: Is it possible?
16-04-2012 2:55 PM
Sorry i forgot over the weekend haha I've rebooted now so you can run your tests 😃
Thanks, Chris x
Re: Is it possible?
16-04-2012 4:07 PM
You'll have to run an up to date BT speed test before I can raise it.
Jojo
Re: Is it possible?
16-04-2012 4:35 PM
1. Best Effort Test: -provides background information.
Download Speed
5.76 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 5.76 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 7.17 Mbps
Upload Speed
0.82 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.82Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
We have identified that you have additional services enabled on you broadband line, please click continue to run advanced service tests.
Re: Is it possible?
16-04-2012 8:51 PM
Also, it drops connection all together every 90 minutes or so, for about 30 seconds, then comes back online.
Look forward to your reply in the morning x
Re: Is it possible?
17-04-2012 2:05 PM
Ok, It looks as though what I did yesterday has now taken effect. I've just changed your profile so you should see a considerable increase shortly.
Jojo
Re: Is it possible?
17-04-2012 3:38 PM
The upload seems to be capped again at around 0.3 though, can you uncap it again for me please?
Thanks x
Re: Is it possible?
17-04-2012 4:34 PM
I've set the profile to give you the uncapped upstream. I'm surprised you're only getting 12.5 speed though. is that wired or wireless?
Jojo
Re: Is it possible?
17-04-2012 4:46 PM
Wireless i get http://www.speedtest.net/result/1899582396.png
So yeah it's decent now 😃 Just the higher upload speed is missing but hopefully that'll improve soon x
Re: Is it possible?
17-04-2012 4:55 PM
Re: Is it possible?
17-04-2012 4:59 PM
I was able to upload a video that normally would have taken about 140 minutes, in 50 a couple of days ago before it capped again so it's all fantastic, thank you so much Jo. I'll let you know if/when the upload increases.
x
Re: Is it possible?
17-04-2012 5:15 PM
The upload is a strange one. When our suppliers set the profile for me it looks like they set it at 448 instead of uncapped. I couldn't place the normal modify order to put it back as it was already showing uncapped. A line check does show the profile as 448 though, so I've used a tool we have to change the profile. If that doesn't work I may have to place an order to cap it, wait as day then place another uncap order. Let me know how it goes.
Thanks.
Jojo
Re: Is it possible?
17-04-2012 11:15 PM
Re: Is it possible?
18-04-2012 3:27 PM
Ok, well as it's set on the back end as uncapped I've placed an order to cap it, then will place an order to uncap it tomorrow. Thanks for your patience. I have detailed this on a ticket.
Jojo
Re: Is it possible?
19-04-2012 11:29 AM
The cap order completed so I've placed the uncap order now. All should be tip-top by tomorrow when it completes.
Jojo
Re: Is it possible?
19-04-2012 2:14 PM
That's fantastic I will of course let you know if all is well tomorrow, thanks again for your superb support, you deserve a pay rise
Chris x
