Is anyone else who is on Fibre seeing a reduced downstream thoughput ?
- Is anyone else who is on Fibre seeing a reduced do...
26-05-2013 5:08 PM
This is the second time on a Sunday late afternoon /evening that i have noticed this happen, in the past 4 weeks whilst connected to the same GW ptw-ag03.plus.net
My downstream throughput ranges from 15mbps to 25mbps less than it normally is, and latency whilst transferring data is noticeably increased, is this due to some kind of throttling of HTTP ?
Is anyone else seeing the same thing today ?
A normal speed test result http://www.thinkbroadband.com/speedtest/button/136958105995657325912.png
Speed tests that show Reduced throughput
http://www.thinkbroadband.com/speedtest/button/136958644727628449959.png
http://www.speedtest.net/result/2732893636.png
Message 1 of 9
(1,435 Views)
8 REPLIES 8
Re: Is anyone else who is on Fibre seeing a reduced downstream thoughput ?
26-05-2013 5:20 PM
Message 2 of 9
(765 Views)
26-05-2013 5:24 PM
Still getting 40+ and 18 upload!!! I'm lucky to get over 0.9 upload.pfft.
Message 3 of 9
(765 Views)
26-05-2013 10:11 PM
The usual peak time jitter /loss of throughput or consistency of throughput, even the Think broadband quality meter shows a little packet loss when i utilise the downstream for speedtests ect,
To me this is evidence of high utilisation somewhere, & why would it be worse on a Sunday ?
Message 4 of 9
(765 Views)
26-05-2013 10:56 PM
Limiting of bursts is a "feature" of traffic management - its also a feature of traffic congestion on the network or an overloaded destination.
Message 5 of 9
(765 Views)
26-05-2013 10:57 PM
Message 6 of 9
(765 Views)
27-05-2013 4:03 PM
Message 7 of 9
(765 Views)
27-05-2013 5:18 PM
Yes i cab see a brief period of jitter on my and some other TBBQM graphs and again followed by a reduction in downstream throughput
should be It's hard to believe that there isn't a capacity issue somewhere, either that or this traffic prioritisation ( aka throttling ) is uber aggressive as it's affecting HTTP traffic Either way something ain't right , oh BTW there will be some who are not affected this could suggest things aren't being or remaining balanced properly over time
Message 8 of 9
(765 Views)
27-05-2013 9:40 PM
Well i decided to Hop Gateways and on this other GW although the jitter is still evident on ping graphs (which would indicate that it's present on the return path) the low throughput issue is more or less resolved ,so is acceptable to me, certainly an improvement
Message 9 of 9
(765 Views)
