Internet status connecting, just wont connect.
- Re: Internet status connecting, just wont connect.
25-11-2017 8:47 AM
I have logged into the router and changed the details to the correct username and password but my connection never gets passed the "connecting" stage, the light just goes back to being red.
I have tried a different router but have had the same result.
Anyone have any other suggestions?
Thanks,
Adam.
25-11-2017 10:57 AM
It could be that PN have not correctly activated your service. Your best bet is to either phone them, patience will be required as this can lead to a long wait on the line. Fortunately this is a freephone number. Alternatively try the on line chat service.
28-11-2017 12:29 PM
Hi @adamk8,
A warm welcome to the forums.
Has this problem been resolved?
Did you receive an email advising you to connect the new router BEFORE you did so?
28-11-2017 12:56 PM
This is still not resolved, I'm currently awaiting a call from the fault team RE a call I made on Friday .
I had an email which said my broadband was ready to go so when I received my router, I tried it straight away.
Just wondering if my account has been correctly activated???
Thanks,
adamk8
28-11-2017 1:07 PM
Adam,
I would not wait...
Is this fibre or ADSL? You could try resetting the router. It is also worth checking out the basics...
Broadband is not going to work well if the "phone" line is not working properly.
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below. From the Q&A list, choose the one which matches the problem, 'open' the 'section' and click the trouble-shooter link. NB: If you receive a failure message (rather than a log-in prompt) then log-in to the user portal in a different browser tab and attempt to use the trouble-shooter again.
