Internet speed normal, but gaming is impossible
- Internet speed normal, but gaming is impossible
- « Previous
- Next »
Re: Internet speed normal, but gaming is impossible
15-10-2015 11:20 PM
You maybe confusing two things cedlor. What one normally has is a switch which changes from Pulse to Tone (and visa versa) and a switch that changes the function of the Recall button from Eth (Earth) to Time Break (TB).
Message 46 of 48
(367 Views)
16-10-2015 10:43 AM
Not totally confused :
Dial mode
There are 3 dial mode settings. Tone/Timed break (TB),
Tone/Earth (TE) and Pulse/Earth (P). The default setting
is Tone/Timed break (TB).
Turn the phone over and move the ModeSwitchto theposition you want: P, TE or TB.
This is the instruction ( not for my phone which only has P and TB) but I think is suggests that Tone Break and Timed break are the same?
Anyway does Gizmo2501 have a switch and what is it set on?
Dial mode
Message 47 of 48
(367 Views)
16-10-2015 10:53 AM
Ah you didn't say it was a three way switch. Those are also quite common as are having two switches. But in any case Tone Break doesn't exist.
It's Tone, and Timed Break for Recall.
Message 48 of 48
(367 Views)
- « Previous
- Next »
