Internet speed has dropped significantly.
- Internet speed has dropped significantly.
- « Previous
- 1
- 2
- Next »
Re: Internet speed has dropped significantly.
16-01-2010 10:49 PM
Sync was no better with the DECT not attached so I don't think you can blame that.
As the sync speeds are pretty consistent no matter what has been tried to looks almost certain to be a problem between the master socket and the exchange.
You need to raise a broadband speed fault if you have not already done so: http://faults.plus.net
Message 16 of 18
(218 Views)
16-01-2010 10:52 PM
Or a damaged master socket, or a faulty router cable - try swapping them (you must have one with each router)
Message 17 of 18
(218 Views)
16-01-2010 11:04 PM
I've tried the router with 3 different cables all with no sucess, the master phone socket looks fine and looks like there is nothing wrong with it.
Thanks for the advice ive just raised a support ticket, and thanks all for your replys your help although unsucessful has been very useful.
adie:quote
adie:quote
Message 18 of 18
(218 Views)
- « Previous
- 1
- 2
- Next »
