Internet goes on and off every 5 mins
- Internet goes on and off every 5 mins
Re: Internet goes on and off every 5 mins
16-12-2010 3:49 PM
only 4 pics and its slow
16-12-2010 3:53 PM
16-12-2010 3:54 PM
right il upload them on photobucket giz a sec.
16-12-2010 4:03 PM
Tada
16-12-2010 4:12 PM
16-12-2010 4:16 PM
the broadband cable that picture its just loose wires and 2 blue wires they wont go in that slot
16-12-2010 4:19 PM
16-12-2010 4:22 PM
16-12-2010 4:24 PM
16-12-2010 4:27 PM
how will i know the stats of my router when its not connected to my PC?
If i took it downstairs it will just be there with the lights on , i dont get it
16-12-2010 4:33 PM
16-12-2010 4:34 PM
when i have my routher and laptop downstairs and into the test socket, how do i test the line?
cheers
16-12-2010 4:36 PM
This totally eliminates your internal wiring - if you still get the same problems JoJo will happily get a BT engineer out.
If you don't get problems it means there is a problem with your internal wiring and JoJo won't call out an engineer as it would almost certainly cost you over £100. If this is the case there are some more tests to be done and there options we can discuss on how to proceed.
Edit: Your laptop will be fine. We want to see the router stats when you are connected to the test socket for a start.
16-12-2010 4:37 PM
The idea is to connect it the router to the test socket and report the full stats and then get JoJo to run the tests they need.
Then leave it down there as long as possible and see if it holds sync
16-12-2010 4:52 PM
How long do i keep my laptop and routher downstairs and what do i do when its there
