Internet flashing orange
- Re: Internet flashing orange
14-10-2020 4:52 PM
I unplugged my router to move some furniture around and now set back up initially I have a blue light but after 30 secs it's now flashing orange, then with have a steady orange light with the flashing b then back to flashing orange. Why is this please?
Message 1 of 4
(544 Views)
3 REPLIES 3
15-10-2020 11:08 PM
The Hub One router will change colour from blue to orange and then back to blue while starting up. It takes around 3 to 4 minutes normally.
Are you still having issues?
Message 2 of 4
(506 Views)
16-10-2020 7:48 AM
It started to work but took a lot longer than 3 to 4 mins. But it has been intermittent still dropping out. I have gone through all the checks and everything is connected I have restarted the router ect and it's still dropping out
Message 3 of 4
(486 Views)
16-10-2020 7:49 AM
Try reporting a fault at http://faults.plus.net
This will create a fault ticket and get you into the queue for Plusnet to investigate further.
Message 4 of 4
(482 Views)
