Internet constantly cutting out
Re: Internet constantly cutting out
Did as you said and did the speedtest on my wireless laptop.
Here's my result:
Fixes: 21
Looking good, let's hope for stability.
Fixes: 5
That's not looking too bad, a little lower than the estimate though. If it's not too much trouble, would you mind keeping on running a few Speed Tests throughout today?
I'm about to chase this issue up now with the escalation owner to get some information on all the work that has been carried out today. I'll keep you updated.
No problem, i'll do them every hour or so and i'll report if there's any drastic changes.
Fixes: 5
Thank you very much, I really appreciate that.
The connection just dropped for about 5 minutes. Speed checks are coming back all about the same.
I looked at the router when the connection dropped and the red light was on, which it didn't always come up on the previous drops, so perhaps an unrelated 'one-off', but i'll still keep my eye on it.
Certainly not a one off. The past half hour its been completely unusable, going on and off literally every minute
Going through the technicolor gateway thing the error in connecting is coming up "Connectivity to Gateway (195.166.128.184)"
I restarted the modem as advised in the Plusnet Assist thing and it seems to have settled down again now. Speedtest now coming up 22 down and 17 up.
Fixes: 5
Thanks for the information here. I'll chase that up again tomorrow morning. As promised I'll give you a call tomorrow and we will get some movement on this.
I haven't been able to go online from about Wednesday until last night. But since I came back on I haven't noticed any drop outs, so could I request one of those graphs to take a look please?
Connection does seem stable at the moment but it's slowed down to about 14/15 down and about 12 up.
Fixes: 5
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13527311749402.png" />
Your connection has been nothing short of sporadic. Have you managed to remove the trim at all? I'd quite like to give you a call this afternoon so we can discuss where we take this from here?
Fixes: 5
Just for your information:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13528204707558.png" />
Connection is looking much more stable now. Will still continue to monitor the situation though.
Fixes: 5
Just another graph to show that the connection is looking pretty stable at the moment.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13529106494374.png" />
Fixes: 21
Blimey, who's fixed what? Did you have any joy finding out if OR had done any external cable repairs Chris (that may have affected several customers perhaps)?
