Internet constantly cutting out
- Re: Internet constantly cutting out
19-10-2012 7:47 AM
My comment in reply #5 was on the assumption was that is was filtered by the vDSL filter.
Is this "wall" just a piece of plasterboard put there to give a"nice" finish? How easy is the cable run from where this BT80/77 is supposedly located to the NTE5a?
19-10-2012 7:59 AM
Yeah, i am removing the filter as well. The engineer who installed was aware and if I remember correctly he just said the extension would be cut off completely. i accepted that and figured i'd find a way to get the sky box connected in the future. Which is why I surprised when he left it still worked but I didn't think much of it at the time.
I've just had a bit of an investigation.. the black wire comes in from outside, then on the left hand side of the door a wire comes out and heads upstairs. From the bottom of the door, another wire goes across skirting boards to the NTE5a.
19-10-2012 8:12 AM
19-10-2012 8:19 AM
Anyhow, I took some pictures to help explain what I mean about the wire coming in through the door:
http://t.co/Of6eljzO
http://t.co/AtZNPvXV
http://t.co/5q9M1uC6
http://t.co/fSKlWKJn
The NTE5a is located on internal wall between the living room and the kitchen.
It comes in the same way at the extension, it seems to split behind the door seal and it comes at the bottom of the seal and then goes across the skirting board in the hall and then into the living room where the NTE5a is located. It's probably the easiest and most straight forward route it could have. The other option would be going all around the outside of the house and come in round the back..
19-10-2012 9:25 AM
This door "seal" that you talk about, is it the 2-3" wide plastic trim above the door frame? (also down the side of the frame on the inner wall(s)).
I guess the "sky socket" room is not on the same side of the house as the front door?
Before the problems, what was the best speed that you were getting?
Now before I comment further, let me directly address the engineer's comments on the ticket -
Quote As stated by previous engineer there is a tap from BT80 or equivalent before NTE5/VDSL2 FRONTPLATE that has been covered up. I explained to Mr Rogerson that this extension would have to be removed completely from the joint for fibre broadband to work without any errors.
This is BS. If there is an internal cable fault then there is know way of knowing whether it is on the run to the NTE5a or to the extension socket, in other words there is no point in disconnecting the extension wiring at the BT80 (given access to it is not readily available). The first thing would be to check and confirm there is an internal cable problem by testing from the external joint on the outside wall. As I said earlier, the wiring and sockets are Openreach's problem as it is all before the NTE5. In one sense this is technically a sub-standard fibre install,. but obviously you don't want any unnecessary disruption to internal decor.
You asked how it would work for 5/6 weeks without a disconnection and then have this problem. Well I expect it's external.
IF you had noticed a speed issue when the Sky was plugged in, then it's possible that the ADSL filter could have gone faulty. However, a standard ADSL filter is not adequate for vDSL. So you should have been provided with another vDSL filter at the "sky socket" by replacing the socket. If there was a speed problem related to plugging in the Sky box, fitting a vDSL filter should solve the problem.
The reason I've been asking all the questions is that the cable from this BT80 is CW1308 standard cable which is not ideal for vDSL. Ideally the incoming black cable should go straight to the NTE5a or it should have been replaced with the higher standard "Data extension cable" - not an easy thing to do in your case.
If your original speed was as fast as was expected considering your distance from the cab, which you have indicated it was, then the easiest solution to the filter issue would probably be for another vDSL plate to be fitted for the extension socket.
Edit: typo and clarification.
19-10-2012 10:05 AM
Yeah that's the seal I mean.
No, sky socket room is above the back door.
When we signed up we were estimated to get 36Mb, once connected we were getting about 34Mb which i'm more than happy with. I then upgraded to the 80/20 mainly for the upload speed, but once upgraded we got 40 up and 17 down, which again I was very happy with.
Since the issues started though, the speed has gone down to about 17 down and 4 up which isn't too great but on o2 we were getting about 1.5 down so it's still fast to us haha.
We don't have anything plugged into the extension at the moment, but i do have a couple of spare ADSL filters, do you suggest me plugging the sky box back in with one of the spare ADSL filters to see if this makes any difference?
19-10-2012 4:06 PM
20-10-2012 3:38 PM
22-10-2012 1:55 PM
Quote The broadband fault has been closed by the supplier. Should problems re-occur, please restart the Broadband Fault Checker.
Our Support Team will respond to your question soon. Please only add further comments when absolutely necessary.
It contradicts itself, however, that's not my worry. My worry is that for some reason, someone has closed the fault ticket when my problem is far from resolved. Starting to lose patience to be honest.
22-10-2012 2:27 PM
22-10-2012 4:02 PM
The ticket is indeed still open but we'll need to reopen the fault with BTw before things can be progressed any further. Suspect it'd be worth updating the ticket with all relevant information then give us a heads up here and we'll give the faults team a nudge to get things moving again for you.
22-10-2012 4:07 PM
The fault ticket #60836709 does have all the info about the problem, along with a link to this thread, so they should have everything needed.
23-10-2012 9:36 AM
23-10-2012 12:58 PM
Quote from: BenXFD The fault ticket #60836709 does have all the info about the problem, along with a link to this thread, so they should have everything needed.
01-11-2012 10:37 PM
