Internet connection drops on incoming phone call.
- Internet connection drops on incoming phone call....
- « Previous
- 1
- 2
- Next »
Re: Internet connection drops on incoming phone call.
15-10-2014 9:44 PM
In sleep mode, it does nothing.. So yes
Kevin
15-10-2014 10:18 PM
Thanks, I will run RouterStats for the next 24 hours or so and see if the increase in the SNR helps.
I called from my mobile to check and the upstream Bit errors jumped from 0 to 1,222 on this call. The connection didn't appear to drop so it may be having some effect on the line or maybe it's intermittent, i will keep checking it and see how it goes.
Ron
17-10-2014 11:59 AM
Just a quick update on this - I've just received a notification that there's an engineer working at the exchange today. Hopefully things will be better after hes completed the task.
17-10-2014 2:33 PM
The BT engineer arrived at my home this morning about 11.30 am. I must say it was a bit of a surprise as i wasn't expecting it, I have just looked at the forum and seen your update. He checked all the line and was very thorough, he changed the wiring a bit, after doing more tests he said the line was looking really good, after completing all his tests he did say the SNR Margin would be better left at 6db as 3 was too low.
So far everything seems to be good, regarding the Bit Errors he did say it should not cause any problems. I will monitor this for a day or two to see how it goes.
Should i reply to the ticket update you left this morning?
Thanks for all your help and the very quick response to this fault.
Ron
20-10-2014 10:11 AM
I've just had a quick glance over this and everything seems to be a lot better.
Hoping this is still the case for you! Let us know if you need anything else.
20-10-2014 10:23 AM
A new view of your modem stats would be useful please.
Are you still seeing spikes in error rates on inbound calls?
Kevin
20-10-2014 12:28 PM
@Jack T. Everything seems fine now, will keep checking for a few days to see how it goes.
@Townman Hi Kevin. Still getting the spike in upstream Bit Errors as you will see from the stats. the BT engineer said this should not cause any problems as i get very few incoming calls, as i can't disagree with this not knowing what the outcome would be if i did get a lot of calls i will monitor the connection and see what happens.
Firmware Version: 1.0.5 Build 140321 Rel.42949
Hardware Version: TD-W8968 V3 0x00000001
System Running Time: 3Day(s) 00:28:45
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Link Power State: L0
Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (0.1 dB): 57 60
Attenuation (0.1 dB): 250 108
Output Power (0.1 dBm): 0 124
Attainable Rate (Kbps): 18,420 1,244
Path 0 Path 1
Downstream Upstream Downstream Upstream
Rate (Kbps): 17,603 1,243 0 0
MSGc (# of bytes in overhead channel message): 51 12 0 0
B (# of bytes in Mux Data Frame): 208 38 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 3 4 0 0
R (# of check bytes in FEC Data Frame): 0 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.3793 0.9968 0.0 0.0
L (# of bits in PMD Data Frame): 4408 313 0 0
D (interleaver depth): 1 1 0 0
Delay (msec): 0 0 0.0 0.0
INP (DMT symbol): 0.00 0.00 0.0 0.0
Super Frames: 0 0 0 0
Super Frame Errors: 1,045 67 0 0
RS Words: 0 1,503,747 0 0
RS Correctable Errors: 0 0 0 0
RS Uncorrectable Errors: 0 0 0 0
HEC Errors: 4,781 66 0 0
OCD Errors: 92 0 0 0
LCD Errors: 92 0 0 0
Total Cells: 1,993,238,992 746,633,985 0 0
Data Cells: 35,277,933 2,754,583 0 0
Bit Errors: 0 4,009 0 0
Total ES: 972 44
Total SES: 0 0
Total UAS: 0 0
The Bit Error numbers are for Two incoming calls.
Ron
20-10-2014 12:39 PM
Wait and watch now....
20-10-2014 1:00 PM
As you say it's wait and watch time now.
Many thanks to you and to everyone for all your help and advice.
Ron.
- « Previous
- 1
- 2
- Next »
