Internet Explorer Offline
- Re: Internet Explorer Offline
19-01-2014 9:07 PM
Had a problem today with my TG582N Router - when using Internet Explorer from my main pc (desktop connected by cable), it would suddenly go to the "Router Username and Password" view. It felt rather warm, and I found that where I had moved it to a few days ago I had it laying on the ventilation holes on the underside blocking them. I turned it off, put it on supports to unblock the vents, and turned it on again after a cooling off period. It seems to be working okay now, but I have found that one of the laptops connected via the wireless network says that Internet Explorer on that particular laptop is working Offline.
Is there something I need to do to get that laptop working Online, or will it sort that problem out itself?
Message 1 of 4
(582 Views)
3 REPLIES 3
19-01-2014 9:28 PM
With Internet explorer open click on Tools scroll down and Untick Work Offline
Message 2 of 4
(386 Views)
19-01-2014 10:03 PM
Done. Working now. Thanks
Message 3 of 4
(386 Views)
19-01-2014 10:05 PM
Your welcome
Message 4 of 4
(386 Views)
