Intermittent very slow speeds
- Intermittent very slow speeds
Re: Intermittent very slow speeds
17-08-2009 9:24 PM
17-08-2009 9:30 PM
I'm luckier than some - I'm within 1km of the exchange and get a solid 6.5M signal most of the time. I turn my router off at night, and when I go out. I retyrn in the evening sometimes about 8pm - turn on and I still get 5.5M, and in the morning get my 6.5M back.
Others find that doing this ruins their routers performance and leave their router on overnight.
Each to his own.
18-08-2009 11:07 AM
Quote from: jayed Surely wasting 8 hours of electricity every day just so I can maintain my sync speed in the evening is not sensible.
I like you
Ultimately it boils down to how important speed is to you. For some people, it is *very* important.
There's a chance that if you turn on your router at certain times of the day, you can experience a lower reconnection speeds. From my perspective, for the majority of the time, I really couldn't care less. I just want to be able to browse the internet.
22-08-2009 12:13 PM
22-08-2009 1:53 PM
Link to the test is here http://www.thinkbroadband.com/speedtest/results/id/125094530756276930943.html
22-08-2009 8:02 PM
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 2240 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 135 kbps
Actual IP throughput achieved during the test was - 26 kbps
This test was not conclusive and further testing is required.
26kbps??? I can't believe I am being charged for a service that my mobile phone can basically provide. I hope this problem gets addressed this time. Every time this happens I get left with a shockingly unusable line for a week until it gets back to speed and then told the problem is sorted when it obviously is not. Maybe I should only be charged for days when my connection is usable. It would save me a bunch of money.
23-08-2009 10:53 AM
You need to try to find out why you had a low sync. Have you got anything plugged in to any phone extension without a filter? Have you moved anything around recently?
23-08-2009 12:35 PM
As for changes, nothing has changed. My hardware has remained unchanged for years other than a changed microfilter due to the previous one being a possible cause of the other 3 line drops so I got a new one. Turns out it made no difference. All computers, cables and router are unchanged for a number of years and have not been moved either. The only change is moving to the Plusnet unlimited package and having this BT thing where it penalises me for long periods for a short blip in connection.
23-08-2009 6:20 PM
It is possible that you have a cable fault so I suggest that you replace the cable between your master socket and router. If you have a modern BT master socket then connect your router to the test socket. Leave your router on all the time and use a program like routerstats to monitor your connection. You need to find out why your sync speed sometimes is so low.
23-08-2009 6:37 PM
24-08-2009 9:23 AM
Quote from: jayed I have actually done a few of those things today. I've moved my router closer to the telephone socket so it is now on a cable about 1 meter long and have run longer CAT cables to my PCs. This means a new cable between socket and router. I've also plugged the micro filter into the test socket. Just have to wait for a speed increase and then see if it remains.
How long was your previous socket to router cable?
24-08-2009 9:43 AM
I've just had a quick look at your line and I can't see anything obviously wrong (apart from the line profile). Glad you've managed to get your router close to your master socket and wired into the test socket. Can you let me know if you continue to see connection drops, if not, hopefully you should see an improvement shortly.
24-08-2009 12:08 PM
24-08-2009 12:11 PM
Keep an eye on how it performs with the test socket. If the connection doesn't drop then definitely have a look at a faceplate.
We can loan you a router if you need to try a different one.
24-08-2009 12:21 PM
