Intermittent very slow speeds
- Intermittent very slow speeds
16-07-2009 6:33 PM
What may be causing this and what can I do to fix it? I've tried different routers so my router is not the issue. I also use linux and windows computers and all have the issue so it isn't the computers themselves.
It's getting very frustrating when it currently looks like 2-3 days every fortnight I have unusable internet speeds.
Re: Intermittent very slow speeds
16-07-2009 6:35 PM
Estimated line speed:
3.0 Mbps - Checked on 2009-03-23 02:49:44
Current line speed:
250
16-07-2009 6:45 PM
You mentioned that you've tried different routers, which is great. Have you also tried wiring the router directly to the master socket, and tried changing the filter?
16-07-2009 6:47 PM
Have you plugged in any new equipment in to any telephone socket in the house recently (phone, sky box, alarm etc)?
16-07-2009 7:00 PM
Quote from: Jameseh Hiya,
Nope. I'm not really sure how to do that but I could try to find out.
16-07-2009 7:01 PM
Quote from: jelv Something is causing your router to resync at a very low speed which sets your BT controlled IP Profile to a very low value.
Nope. Nothing new at all. Only thing plugged into the phone is one phone and the router.
16-07-2009 7:02 PM
http://community.plus.net/forum/index.php/topic,77794.0.html
16-07-2009 7:04 PM
16-07-2009 7:06 PM
Quote from: Jameseh @Jayed - I meant to connect your router to your master telephone socket via a microfilter.
Yeah, I just reread that. I only have one telephone socket so I guess it must be the master socket. I also use a microfilter.
16-07-2009 7:12 PM
I've just increased your profile slightly in line with that of BT. You should notice a slight improvement if you reboot your router.
I'd recommend that you raise a fault via http://faults.plus.net as an intermittent connection as your connection drops are causing your speeds to fluctuate.
16-07-2009 7:16 PM
16-07-2009 7:17 PM
16-07-2009 7:17 PM
16-07-2009 7:19 PM
16-07-2009 7:21 PM
Should I turn my router off? I prefer not to have it on if it's not in use for a long period.
