Intermittent loss of DNS (from more than one location)
- Re: Intermittent loss of DNS (from more than one l...
25-07-2012 1:45 AM
I've noticed a couple of times that although I still have some some internet connectivity I cannot ping the DNS servers or get any response from them, and therefore cannot connect to sites.
Here is an example, probably taken between 50 and 60 minutes ago.
Here's what it looks like when working:
So, looks like the network dropped out somewhere between lo0-central10.pcl-ag07.plus.net and broadband.plus.dyn.plus.net on this occasion, though I haven't kept logs for the previous occasions.
I'm not alone. I'm on 020 8805 exchange. My parents (on 020 8524 exchange) were getting something very similar when I looked at their machine on Sunday
Why are DNS1 and DNS2 consecutive net addresses? By my understanding, DNS2 should be in a vastly different subnet from DNS1, so that it can take over if a network disruption makes the first DNS unreachable. And perhaps, as with many other ISPs, there needs to be more than just two of them ?
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Harry>tracert -d 11.11.11.11
Tracing route to 11.11.11.11 over a maximum of 30 hops
1 28 ms 99 ms 99 ms 192.168.1.254
2 13 ms 13 ms 13 ms 195.166.128.182
3 ^C
C:\Users\Harry>tracert -d bbc.co.uk
Unable to resolve target system name bbc.co.uk.
C:\Users\Harry>tracert -d 212.159.6.9
Tracing route to 212.159.6.9 over a maximum of 30 hops
1 94 ms 99 ms 99 ms 192.168.1.254
2 13 ms 14 ms 14 ms 195.166.128.182
3 * * ^C
C:\Users\Harry>nslookup
Default Server: dsldevice.lan
Address: 192.168.1.254
> server 212.159.6.9
DNS request timed out.
timeout was 2 seconds.
Default Server: [212.159.6.9]
Address: 212.159.6.9
> bbc.co.uk
*** Request to [212.159.6.9] timed-out
C:\Users\Harry>ping -t 212.159.6.9
Tracing route to cdns01.plus.net [212.159.6.9]
over a maximum of 30 hops:
1 52 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 13 ms 12 ms 13 ms lo0-central10.pcl-ag07.plus.net [195.166.128.188
3 12 ms 12 ms 12 ms 84.93.249.204.broadband.plus.dyn.plus.net [84.93
.249.204]
4 13 ms 12 ms 11 ms xe-2-2-0.pcl-cr01.plus.net [212.159.1.12]
5 12 ms 12 ms 12 ms po2.pcl-gw01.plus.net [195.166.129.41]
6 12 ms 11 ms 12 ms vl63.pcl-lb01.plus.net [212.159.2.252]
7 12 ms 12 ms 11 ms cdns01.plus.net [212.159.6.9]
Message 1 of 6
(2,653 Views)
5 REPLIES 5
Re: Intermittent loss of DNS (from more than one location)
25-07-2012 6:14 AM
You are not obliged to use Plusnet's own DNS servers. You could try:
Google: 8.8.8.8 , 8.8.4.4
OpemDNS: 208.67.222.222 , 208.67.220.220
and there are many many more.
Message 2 of 6
(746 Views)
25-07-2012 12:36 PM
There's murmurings in the support centre that the odd customer is still calling to report data transfer problems. I'm not convinced it's anything to do with DNS mind you. It's more likely related to a particular edge router, traffic management switch or customer IP range. We're collecting examples at present in order to try and ascertain some sort of pattern.
They're virtual IP addresses which sit in front of eight physical boxes spread across multiple data centres.
Quote from: harry Why are DNS1 and DNS2 consecutive net addresses? By my understanding, DNS2 should be in a vastly different subnet from DNS1, so that it can take over if a network disruption makes the first DNS unreachable. And perhaps, as with many other ISPs, there needs to be more than just two of them ?
Message 3 of 6
(746 Views)
25-07-2012 2:05 PM
Quote eight physical boxes spread across multiple data centres.
That sounds good, but then I do tracert to each DNS ...
1 48 ms 98 ms 98 ms dsldevice.lan [192.168.1.254]
2 12 ms 12 ms 13 ms lo0-central10.pcl-ag02.plus.net [195.166.128.183
3 12 ms 12 ms 12 ms 84.93.249.48.broadband.plus.dyn.plus.net [84.93.
249.48]
4 12 ms 12 ms 12 ms xe-0-2-0.pcl-cr01.plus.net [212.159.1.0]
5 11 ms 12 ms 12 ms po2.pcl-gw01.plus.net [195.166.129.41]
6 13 ms 12 ms 13 ms vl63.pcl-lb01.plus.net [212.159.2.252]
7 12 ms 12 ms 13 ms cdns01.plus.net [212.159.6.9]
Tracing route to cdns02.plus.net [212.159.6.10]
1 51 ms 99 ms 98 ms dsldevice.lan [192.168.1.254]
2 12 ms 12 ms 12 ms lo0-central10.pcl-ag02.plus.net [195.166.128.183
3 11 ms 12 ms 12 ms 84.93.249.40.broadband.plus.dyn.plus.net [84.93.
249.40]
4 11 ms 11 ms 12 ms xe-0-2-0.pcl-cr01.plus.net [212.159.1.0]
5 99 ms 79 ms 12 ms po2.pcl-gw01.plus.net [195.166.129.41]
7 13 ms 12 ms 12 ms cdns02.plus.net [212.159.6.10]
It looks to me as if there are still 6 out of 7 possible common failure points between me and both of the DNS servers.
Of course, it could possibly use a different route when one of the above is down -- but as yesterdays trace shows, it doesn't always use any route at all.
Message 4 of 6
(746 Views)
25-07-2012 2:12 PM
Quote from: ReedRichards You are not obliged to use Plusnet's own DNS servers
Agreed. I used to have OpenDNS appended at one time, but haven't previously needed it with plusnet. Problem there is you have to decide to do it before the DNS goes down (or, at least, have to keep a local copy of the openDNS addresses).
I'm less to add google's. Do we really need google keeping a log of every DNS access we do, especially as google makes it clear these days that privacy isn't one of google's main attributes.
jim:green quote fixed mod:end
Message 5 of 6
(746 Views)
25-07-2012 2:29 PM
Quote from: harry It looks to me as if there are still 6 out of 7 possible common failure points between me and both of the DNS servers.
It's not quite as simple as that. OSPF is used to route your traffic to the closest caching DNS server. This tends to be based on the edge router your connection is terminated on. If one route is broken another would be taken. The two sets of DNS servers are located in London data centres that are miles from each other.
Regarding the data transfer problem itself, we've identified some overlapping IPs that would have led to the symptoms you describe (ref: 72177). We've fixed those conflicts and are currently carrying out an audit to make sure there aren't any more. Let me know if the problem resurfaces ...
Message 6 of 6
(746 Views)
