Interleaving on 0r off?
- Re: Interleaving on 0r off?
13-06-2012 8:27 AM
rather than raise a ticket for this is it possible to check if interleaving is on. If so is it possible to turn it off? I recieved the router yesterday and now have it running and all seems to be ok
Download speedachieved during the test was - 19.87 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 21.35 Mbps
there are no drops in the time it has been connected
Uptime: 0 days, 12:23:34
Harps1h
13-06-2012 10:05 AM
13-06-2012 10:24 AM
Interleaving was set to Auto, not sure whether it was being applied or not (checking what jelv says above should tell you that) but I've placed an order to remove it anyway for you - it should complete tomorrow.
13-06-2012 12:04 PM
Uptime: 0 days, 16:03:13
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,259 / 24,200
Data Transferred (Sent/Received) [MB/GB]: 132.81 / 1.21
Output Power (Up/Down) [dBm]: 12.3 / 0.0
Line Attenuation (Up/Down) [dB]: 2.9 / 8.0
SN Margin (Up/Down) [dB]: 6.3 / 3.0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 27 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 28 / 65
HEC Errors (Up/Down): 50 / 2,706
13-06-2012 12:48 PM
13-06-2012 1:06 PM
14-06-2012 8:02 PM
14-06-2012 8:45 PM
dick:quote
14-06-2012 8:55 PM
14-06-2012 9:03 PM
14-06-2012 9:10 PM
14-06-2012 9:14 PM
14-06-2012 9:18 PM
Quote from: jelv FEC errors only happen when interleaving is ON.
14-06-2012 9:26 PM
15-06-2012 8:27 AM
