Interleaving - apparently turned off?
- Interleaving - apparently turned off?
- « Previous
- 1
- 2
- Next »
Re: Interleaving - apparently turned off?
14-05-2010 1:47 PM
Hi r3fl3x , I hope you have as good a results as what I have been having.
Seems to be getting better and better for me all the time.
I pinged the 2 sites you did earlier in the thread again and here's the results -
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Picks>ping www.theregister.co.uk
Pinging www.theregister.co.uk [212.100.234.54] with 32 bytes of data:
Reply from 212.100.234.54: bytes=32 time=16ms TTL=58
Reply from 212.100.234.54: bytes=32 time=15ms TTL=58
Ping statistics for 212.100.234.54:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 15ms, Maximum = 16ms, Average = 15ms
C:\Users\Picks>ping www.bbc.net.uk
Pinging www.bbc.net.uk [212.58.246.158] with 32 bytes of data:
Reply from 212.58.246.158: bytes=32 time=17ms TTL=56
Reply from 212.58.246.158: bytes=32 time=16ms TTL=56
Ping statistics for 212.58.246.158:
Minimum = 16ms, Maximum = 17ms, Average = 16ms
Cheers
Paul.
Cheers
Paul.
Message 16 of 18
(237 Views)
14-05-2010 2:07 PM
Cor I hope so, Paul - gotta be 10+ms off them minimum from what I've seen of everyone else's pings...
Will make a massive difference to my MW2 gaming - particularly with the uncapped upstream. <20ms pings would be delicious across the UK. Especially as MW2 essentially uses geo-based P2P to find hosts.
BOOM! Headshot.
Message 17 of 18
(237 Views)
14-05-2010 2:19 PM
I have been playing cod4 on a dedicated american server for a year or more now , I always used to get a latency of between 140-160 , maybe 135 on a real good day.
On the exact same server after having interleaving switched off the worst I get is 130 , normally its between 110-120 and I have had as low as 100.
I know these all sound high , but like I say , its an american server.
But as you can see , there is a pretty good reduction in latency.
On half life 2 , I regularly get a latency of 5ms on European servers!
Edit: Just tried a UK server in cod4 , best latency I got was 33 which ain't too bad I guess.
Cheers
Paul.
Cheers
Paul.
Message 18 of 18
(237 Views)
- « Previous
- 1
- 2
- Next »
