Interleaving Depth 1
- Interleaving Depth 1
- « Previous
- 1
- 2
- Next »
Re: Interleaving Depth 1
18-05-2016 4:24 PM
Taking a look now, give me a few minutes.
18-05-2016 4:33 PM
Your line has been dropping a bit more than I'd like to see, with the 7th and 8th particularly poor.
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 34.8 | 55.0 |
SNR Margin: | 6.0 | 16.0 |
Errored Seconds: | 4 | 3 |
HEC Errors: | 3 | |
Cell Count: | 440907 | 2828133 |
Speed: | 768 | 2208 |
Maximum Stable Rate (KBPS): | 2016 | Fault Threshold Rate (KBPS): | 1612 |
Mean Time Between Retrains (Seconds): | 43100 | Mean Time Between Errors Upstream (Seconds): | 140 |
Indicative Line Quality: | A | Mean Time Between Errors Downstream (Seconds): | 10 |
From the stats above, the MTBR (Mean Time Between Errors) is very low, particularly on the downstream. With that being so low, it's a risk to reduce the SNR any further. Adding interleaving to try and combat the errors is a suggestion, however this may also cause your speed to slightly reduce again. Is the router in the master socket at the moment? No extension leads in place?
18-05-2016 5:02 PM - edited 18-05-2016 5:04 PM
Yes in the master socket,no extensions
Have done the quiet test as said in the beginning of this thread,all fine,no noise/hiss
The drops you mentioned could very well be my fault.Was trying different routers a while back
Present router was connected since sunday with no fiddling at my end untill an hour ago when i reset it it
18-05-2016 5:39 PM
There has been a 1dB rise in the SNRM between your restart and the figures Chris reported. Have you got router stats running? That shift suggests that there is something generating noise. You might have to do some digging here!
That SNRM is quite high and yet there is still a very low MTBE. I take it that the CLT is coming up clean - no obvious line fault? What is the a/c balance like please?
The stats look quite odd. Do you think REIN could be involved here?
- « Previous
- 1
- 2
- Next »
