Interleave Off?
- Interleave Off?
Interleave Off?
11-10-2008 11:33 AM
Re: Interleave Off?
11-10-2008 12:24 PM
Edit - this is the link to the interleaving control https://portal.plus.net/my/account_maintenance/interleaving_control.html
Re: Interleave Off?
11-10-2008 12:32 PM
Does this mean its turned off or do i need to use a ticket to turn it off?
Re: Interleave Off?
11-10-2008 12:45 PM
Re: Interleave Off?
11-10-2008 1:34 PM
Re: Interleave Off?
11-10-2008 1:58 PM
Re: Interleave Off?
11-10-2008 4:40 PM
I've raised a support ticket so il see what difference interleaving makes on monday, hopefully my speed profile will be working then aswel.
Re: Interleave Off?
11-10-2008 4:42 PM
You can also navigate to this ticket by going to Help and Support > Help Assistant > My Broadband Connection > DSL Interleaving
HTH
Edit: The "Idle Timeout" is for some legacy products - there are no timeouts on BBYW products!
Re: Interleave Off?
11-10-2008 4:57 PM
Re: Interleave Off?
12-10-2008 2:48 PM
Seems a bit much, i just hope that my line doesnt need it.
Re: Interleave Off?
12-10-2008 5:41 PM
Re: Interleave Off?
12-10-2008 8:39 PM
As was explained above, different accounts get different buttons/functionality in the control panel - so some functions may not be available for your account.
PS. With the recession BT will start charging for anything and everything it can - Interleaving might be one of those things.
Re: Interleave Off?
13-10-2008 9:06 AM
