Interleave Depth: 96
- Interleave Depth: 96
03-10-2013 9:53 AM
My router is reporting that my downstream connection is running with an interleave depth of 96. Is this something I should be concerned about? If so how do I get it changed?
It is probably relevant that 1 month ago I had a line fault that was fixed by BT. There was a break in one conductor close to the cabinet. Service has been stable since though I have occasionally rebooted the router in case that would automatically pick up a revised setting. Last time today at c. 06:50 after running for 7 days.
Thanks for any advice.
Router stats:
Downstream
Noise Margin: 3.4 dB
Connection Rate: 15680 Kbps
Line Attenuation: 30.5 dB
Power: 0.0 dBm
Max Rate: 18872 Kbps
SuperFrames: 644552
SF (CRC) Errors: 6
Reed Solomon: 143090644
RS Corrected: 649617
RS Un-Corrected: 219
HEC: 5
Errored Seconds: 5
Severe ES: 0
Bitswaps: 920
Upstream
Noise Margin: 6.0 dB
Connection Rate: 1164 Kbps
Line Attenuation: 15.4 dB
Power: 12.9 dBm
Max Rate: 1164 Kbps
SuperFrames: 587956
SF (CRC) Errors: 0
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 0
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 1
Bitswaps: 0
Summary
Total Uptimes (From SF counts):
WAN: 0 days, 02:54:39
LAN: 0 days, 02:54:39
CRC: 6
LOS: 0
LOF: 0
ES : 5
Bytes Transferred (ppp0):
Tx: 28241158 (26.9 MiB)
Rx: 53727371 (51.2 MiB)
IP address: 87.114.***.***
Router stats:
Downstream
Power: 0.0 dBm
SuperFrames: 644552
SF (CRC) Errors: 6
HEC: 5
Errored Seconds: 5
Severe ES: 0
Bitswaps: 920
Upstream
Power: 12.9 dBm
Max Rate: 1164 Kbps
SuperFrames: 587956
SF (CRC) Errors: 0
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 0
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 1
Bitswaps: 0
Summary
CRC: 6
LOS: 0
LOF: 0
ES : 5
Message 1 of 2
(1,219 Views)
1 REPLY 1
Re: Interleave Depth: 96
03-10-2013 10:08 AM
It mean u are interleaved on because of
Message 2 of 2
(779 Views)
