For the past couple of days my "routerstats" has been showing a Rx synch rateof 2144
Downstream Upstream
Rate (Kbps): 2144 448
SNR Margin (dB): 3.2 20.0
Attenuation (dB): 63.5 25.0
Output Power (dBm): 12.1 19.1
the speedtest.net gives me
the Mybroadband speedtest gives me
and the BT speedtest gives me
Test1 comprises of
Best Effort Test: -provides background information.
Download Speed
1305 Kbps 0 Kbps
2000 Kbps
Max Achievable Speed Download speedachieved during the test was - 1305 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :
2144 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1500 Kbps
As my "max achievable speed" is 2000 Kbps.... and I am currently synch at 2144 Kbps..... just wondered why my profile is 1500Kbps......? and the
"best effort" is only 1305 Kbps !
Have a steady solid connection, no dropouts, not particularly worried about the actual speed of 1.4 Mbps...... if it went up to 1.8 I doubt if I would notice any difference "on the screen". as I don`t do gaming....
Just wondered.....!
