Information required re 21CN
- Information required re 21CN
22-04-2009 11:33 AM
According to Usertools, my exchange will be enabled for 21CN sometime between 1st October 2009 and 31st March 2010. Is there anyway that I can be informed of when it does go live or do I just have to keep an eye on the Usertools web page?
Message 1 of 4
(991 Views)
3 REPLIES 3
Re: Information required re 21CN
22-04-2009 11:44 AM
Do you mean 21CN which is the telephony system or the WBC which is the ADSL2+ broadband upgrade.
Message 2 of 4
(482 Views)
22-04-2009 11:50 AM
if you go to http://www.samknows.com/broadband/exchange you can get anRSS feed to keep you up to date
the stats for my exchange are odd
BT Wholesale information
ADSL status: Enabled as of 30/06/2001
ADSL Max status: Enabled as of 31/03/2006
SDSL status: Not available
21CN WBC status: RFS date set : 30/09/2009
21CN PSTN switchover target: Q2 2009
Message 3 of 4
(482 Views)
22-04-2009 1:01 PM
Should've thought of that - thank you Pierre - all sorted.
Message 4 of 4
(482 Views)
