Increased spam
- Re: Increased spam
Increased spam
04-04-2008 4:58 PM
Has anyone else noticed an increase in spam over the last 48 hours. I have always had my spam filter off and used to get 5-6 spams per day, now I am getting around 25-30 per day. Have PN done something to increase spam in the last day or so, I know there has been mods to the spam system but I assumed it would have decreased the spam
Message 1 of 5
(1,044 Views)
4 REPLIES 4
Re: Increased spam
04-04-2008 5:06 PM
Even with your spam filter off, you may have been protected by Blatant Spam Blocking, which may be no longer the case....
I don't know, but the point is you should check your spam settings again in Manage My Mail, now that the tool has been improved. You may decide you need Edge Protection, even if you don't want Spam Filtering, for instance....
Message 2 of 5
(360 Views)
Re: Increased spam
04-04-2008 5:22 PM
Chris, Blatant Spam Blocking should be enabled by default but I suppose there's no harm in double checking
Message 3 of 5
(360 Views)
Re: Increased spam
04-04-2008 5:29 PM
Just checked - edge protection is on
I'll try with the spam filter on and hope i don't get too many false positives - the reason I turned it off
Message 4 of 5
(360 Views)
Re: Increased spam
04-04-2008 6:01 PM
Paul, are lots of the spams apparently coming from your plusnet domain?
Due to a slight misunderstanding all emails coming (or rather appearing to come) from plus.com addresses might be being whitelisted.
The fix to this is to go to your email spam settings and update the whitelist (without changing anything)
Message 5 of 5
(360 Views)
