Increase IP Profile
- Increase IP Profile
- « Previous
- 1
- 2
- Next »
Re: Increase IP Profile
03-03-2012 1:22 AM
The full version of Routerstats from http://www.vwlowen.co.uk/internet/files.htm works well with the TG585v8 for monitoring the connection (select the Speedtouch v6,v7 option).
Some guidance on suitable configuration settings is given in this post. Note that some of the later replies are based on use of a much older version of the program.
David
Message 16 of 23
(413 Views)
06-03-2012 10:26 AM
Hi DJ1UK,
It looks like your 6000 profile is back. Have you seen the increase at your end?
Jojo
Jojo
Message 17 of 23
(413 Views)
06-03-2012 10:48 AM
Hi Jojo,
Sorry for not updating this thread. Yes speed back to normal around 5.5.
Had a blip on Saturday night where it went back down to 0.5mb, but seems to have restored itself. Connection has been stable since then.. just over 2 days.
I changed all micro-filters, so maybe one of them was faulty.
Thanks for your help... a great service.
Router info looks like this.. is everything ok.. SN margin high? I'm happy the way things are
Uptime: 2 days, 0:13:41
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,124 / 7,296
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,232
Data Transferred (Sent/Received) [kB/GB]: 0.00 / 1.08
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 13.0 / 22.5
SN Margin (Up/Down) [dB]: 26.0 / 15.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 488
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): 0 / 2
DJ.
DJ.
Message 18 of 23
(413 Views)
06-03-2012 3:05 PM
Hi DJ1UK,
Thanks for letting me know. SNR does seem to be a little high. Would you like me to try and lower it and see what happens?
Jojo
Jojo
Message 19 of 23
(413 Views)
06-03-2012 3:50 PM
Sure if you think it'll help, please try and reduce the SNR.
I'm not too techy...! Will this increase my speed?
Thanks, DJ.
Thanks, DJ.
Message 20 of 23
(413 Views)
06-03-2012 3:56 PM
Yes, it should. I'll give it a go and check on it before I go home. It can sometimes reset quickly but can take up to 24 hours
Message 21 of 23
(413 Views)
06-03-2012 4:23 PM
Ok so my dsl just reset and SNR reduced and bandwidth up;
DSL Connection
Uptime: 0 days, 0:04:46
Channel mode: Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,160 / 8,128
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 918.00
Output Power (Up/Down) [dBm]: 11.5 / 20.0
SN Margin (Up/Down) [dB]: 27.0 / 11.5
Loss of Signal (Local/Remote): 5 / 0
Error Seconds (Local/Remote): 5 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Will wait and see if it stays stable.
Thanks!
DSL Connection
Channel mode: Fast
Thanks!
Message 22 of 23
(413 Views)
06-03-2012 4:49 PM
I've just changed your profile to 7150Kbps, so you should see the increase shortly
Message 23 of 23
(413 Views)
- « Previous
- 1
- 2
- Next »
