Improving my connection
- Improving my connection
13-09-2009 2:13 PM
Hello,
I'm a newbie here on the community forums but have been with plusnet for years with no real problems.
I have a mac pro and an aging windows computer and will soon be using just the mac. My question is this; I want to improve the wiring from the BT box to the router (Netgear DG834 v4) to get the best speed I can. Should I get a BTNTE5 adaptor from www.clarity.it/ or use some other filter. What's the latest on getting the cleanest signal into the router. As I am redecorating, now is the time I can run new cables.
Thanks in advance,
nailbone
Thanks in advance,
nailbone
Message 1 of 4
(904 Views)
3 REPLIES 3
Re: Improving my connection
13-09-2009 2:33 PM
A warm welcome to the forums nailbone.
Assistance will be along shortly now that the F1 has finished
Message 2 of 4
(433 Views)
13-09-2009 5:30 PM
Quote from: nailbone What's the latest on getting the cleanest signal into the router.
Connect the router directly to the BT NTE5 master socket.
Disconnect the bell wire if you have any extension sockets - or use an i-plate, filtered faceplate etc.
Message 3 of 4
(433 Views)
16-09-2009 6:57 AM
Thanks guys, I'll order one and be back later for advice on optimizing the router.
nailbone
nailbone
Message 4 of 4
(433 Views)
