Imagevenue
- Imagevenue
Imagevenue
30-05-2011 8:19 PM
For example: <link removed> does not work.
But <link removed> is fine.
Could you please let me know if these work for you?
I have disabled the firewall to no avail.
I have reconnected to PN to use differing gateways - no difference.
I can sucessfully connect to both when using TOR so I know the sites are up.
When using <link removed> the report says it is up - but not for me!
Any ideas.
Thanks in advance
[Moderator's note by Jim (Oldjim) The links have been removed see post http://community.plus.net/forum/index.php/topic,96186.msg811337.html#msg811337 ]
Re: Imagevenue
30-05-2011 8:26 PM
Re: Imagevenue
30-05-2011 8:30 PM
Re: Imagevenue
30-05-2011 8:34 PM
Google result
Prev - ImageVenue.com - Image Hosting and Image Upload
SexyAngel2007. Next>>
img40.imagevenue.com/gallery/.../900_1363_SexyAngel2007.php - Cached - Similar
A sexy celeb thread (my comeback) [Archive] - eBaum's World Forum
http://img40.imagevenue.com/loc1/th_655_Rosamund_Pike_1.jpg (http://img40.
imagevenue.com/img.php?loc=loc1&image=655_Rosamund_Pike_1.jpg) ...
forum.ebaumsworld.com/archive/index.php/t-99521.html - Cached - Similar
Re: Imagevenue
30-05-2011 8:40 PM
Strange how some imagevenue servers work and others don't.
How do I find out whether the site is banned by Plusnet?
Re: Imagevenue
30-05-2011 8:43 PM
Edit - image removed as it might change to something nasty
Re: Imagevenue
30-05-2011 8:47 PM
Re: Imagevenue
30-05-2011 8:50 PM
Re: Imagevenue
30-05-2011 8:56 PM
I know that the images are fine. The content isn't the problem.
Seems like some can connect to both and some only one.
Re: Imagevenue
30-05-2011 9:02 PM
Try Google for img40.imagevenue.com porn and see what comes up.
It is quite likely that great chunks of that site fall foul of the child porn block
Re: Imagevenue
30-05-2011 9:13 PM
If it is being blocked why can some users see it and others cannot?
Can I find out if certain servers are subject to filtering/blocking?
Re: Imagevenue
30-05-2011 9:59 PM
Re: Imagevenue
31-05-2011 4:52 AM
Re: Imagevenue
31-05-2011 2:10 PM
I'm not having much luck with the ticket I raised with PlusNet Support.
They're not even reading the ticket properly!
The site is definitely up - some PN customers can see it some can't. Why I wonder?
dick:quote
Re: Imagevenue
31-05-2011 2:27 PM
