Idle Timeout / Disconnections
- Idle Timeout / Disconnections
15-05-2012 6:00 PM
Re: Idle Timeout
15-05-2012 6:05 PM
Well the idle time out setting on the router' setup page should be set to 0 (that's zero)
The other settings as I recall to check are VPI set at 0 and VCI set at 38
Re: Idle Timeout
15-05-2012 6:09 PM
Re: Idle Timeout
15-05-2012 6:12 PM
Re: Idle Timeout
15-05-2012 6:38 PM
If you can't find the information displayed or it's displaying the incorrect value and you need to change it you may need to Telnet into the modem/router, but that is starting to get very technical and it doesn't sound to me as though that is something you should be messing in with your technical ability.
Did you make it clear to faults about this idle timeout message? If not, I'd go to the Ticket, add that information and then ring up and ask for some guidance.
Edit: Just to be clear, apart from the error messages, your Broadband light is solid Green, but your Internet light goes Red or Off?
Re: Idle Timeout
16-05-2012 12:09 AM
Re: Idle Timeout
16-05-2012 1:05 AM
Re: Idle Timeout
17-05-2012 1:08 AM
Re: Idle Timeout / Disconnections
17-05-2012 2:26 AM
It certainly worth a try using a different router, just to rule out the one you are using causing the problem. If you still have your old Sky router though, you won't be able to use this with Plusnet.
Apart from that the only other thing you can do is raise a fault for the disconnections if you cannot fix it with changing the filters, router, unplugging everything and your in the test socket...you can raise a fault here though - https://faults.plus.net
17-05-2012 4:06 AM
Thanks.
Re: Idle Timeout
17-05-2012 4:22 AM
Quote Edit: Just to be clear, apart from the error messages, your Broadband light is solid Green, but your Internet light goes Red or Off?
I have just been disconnected again, and this time had enough time to go and look at the router, the (broadband) light was blinking, and the (internet) light was off, this lasted for about a minute before the (broadband) light was solid again and the (internet) light come on again.
17-05-2012 5:54 AM
Quote from: scream If you still have your old Sky router though, you won't be able to use this with Plusnet.
That is not necessarily true, although many Sky routers are 'locked' to the Sky configuration, some can be 'unlocked' so that they can be used with any ISP.
For example, the last three routers I bought from eBay were Sky 'locked' DG834GT models, which I flashed with either the Netgear or DGTeam firmware, and are now all being used successfully on Plusnet connections by friends and family.
17-05-2012 5:57 AM
17-05-2012 6:15 AM
17-05-2012 10:09 AM
https://adsl24.co.uk/forum/showthread.php?t=2320
This sounds similar. What router are you using?
