ISP Connect Trial - 21CN trial
- ISP Connect Trial - 21CN trial
Re: ISP Connect Trial - 21CN trial
13-05-2009 12:07 AM
Quote from: itsme Have you upgraded to iPlayer Desktop? There have been a lot of posting on the iPlayer forums that the downloading is a lot slower with the Desktop version.
I'm on iPlayer Desktop and it's not its fault - I've switched back to RIN and the two programs I'm downloading are coming down so fast that it's making these forums stutter like crazy.
I'm also getting nearly as fast on the normal Plusnet connection.
There's definitely something wrong with either 21CN or THN-AG2
Don't forget I'm on PAYG (equivalent of PRO) so all traffic should be gold or better.
13-05-2009 12:15 AM
Quote from: ASBO http://community.plus.net/forum/index.php/topic,76296.0.html
been like it for 3 days now jelv.
I was reading that thread when you posted - I'm sure it's the same problem.
I'm not a Wireshark addict so I haven't checked what the traffic is classed at, but unless someone has totally screwed up the configuration it shouldn't make any difference - I'm on PAYG so all my traffic should be gold or better.
Quote from: ASBO how come you can change back to the centrals on connect
There's no exchange wiring change for IPStream Connect - it's all down to routing controlled by the radius servers. All I do is change the login.
username@plusdsl.net - normal centrals
username@plusdsl2.net - RIN
username@plus11.net - IPStream Connect
13-05-2009 12:16 AM
Quote Don't forget I'm on PAYG (equivalent of PRO) so all traffic should be gold or better.
does that mean gold plated 0x60 and gold 0x80.
or is PAYG just 0x80
13-05-2009 12:19 AM
i wish i could switch back an forth
13-05-2009 12:23 AM
13-05-2009 12:32 AM
13-05-2009 12:42 AM
i can get to sleep now safe in knowledge that you guys are finding and pointing problems out too
night jelv, fancy lending me one of your 2 gd connections
13-05-2009 12:43 AM
13-05-2009 12:52 AM
Wish I'd done this before midnight when the speed was
Not sure about the RIN result as I sync at 8192!
13-05-2009 3:12 PM
Speeds may be slightly down as I have VPN connected and a RDP session open.
13-05-2009 5:43 PM
streaming 1 is classed as 0x60 gold plated using an ip of 88.221.26.173
i did about 6 tests and 2 of them where all 0x80's . so the same ip is not used every time. but it was only streaming 1 that was classed as 0x60 every time.
Any way dave's updated my ticket on this
Quote I'm currently looking into this and see whether we can fish out the remaining iPlayer traffic from the Akamai and Limelight network ranges, we may have another sig we can test soon so hopefully this will detect the rest.
13-05-2009 5:54 PM
Err... Exactly how will that help when the speed of my 0x80 (PAYG Gold) traffic was dire last night?
I think it's a far more fundamental problem than whether it is Gold or Gold Plated.
13-05-2009 6:03 PM
all i know is wbc and seems connect as well now are not happy bunnys at all between midnight-1am
i will jump out of this thread now and leave it to you connect guys as there's maybe somthing diffrent going on with connect product
gd luck with it jelv and least you have 2 other connections to fall back on
13-05-2009 6:10 PM
Quote from: ASBO gd luck with it jelv and least you have 2 other connections to fall back on
Not quite as simple as that.
I know the normal Plusnet connection does not perform as well as RIN. However see http://community.plus.net/forum/index.php/topic,75842.0.html
I was hoping that IPStream Connect would step in to the void left by RIN's ending.
14-05-2009 11:05 AM
We've had some problems recently where we've seeing packet loss on THN-AG2 before we even hit capacity, which Dave has been investigating with BT.
