IPStream Connect - 5 volunteers needed
- Re: IPStream Connect - 5 volunteers needed
16-06-2009 12:36 PM
I would like to do this as well
stuart
16-06-2009 12:38 PM
You can't have both..
16-06-2009 12:39 PM
Quote from: ENSORS Hi
stuart
Quote from: Jameseh ...and that's our lot.
Thanks everyone.
Perhaps this topic should now be locked?
16-06-2009 12:45 PM
19-06-2009 5:36 PM
maranello
godsell4
adiewoo
Oldjim
Paul03
ENSORS
hughconway - as you're on 21CN already at the moment we can't add you to this trial. I don't know how long this phase of the trial will run for so it may have finished by the time you've moved house, but if you are on the IPSC trial then moving to ADSL2+ makes no real difference as far as the process is concerned (although you will have to change the username in your router).
Should be able to get all 6 of you on, I'll be touch when the config work is done and let you know what to change the username to.
The reason for a small number at this stage is because we want to test out the process of moving a whole realm from 20CN to IPStream Connect. So the plan is to set you guys up with a completely new realm then move that in exactly the same way as we will do when we get to the next phase of the trial (that'll be when the numbers start to increase - slowly).
Plusnet Technology
19-06-2009 5:39 PM
19-06-2009 6:05 PM
22-06-2009 5:51 PM
22-06-2009 10:53 PM
Plusnet Technology
25-06-2009 3:46 PM
Plusnet Technology
25-06-2009 5:11 PM
Just tried again and still getting CHAP authentication failed
25-06-2009 5:43 PM
25-06-2009 6:29 PM
plus12.net does only point at pcl-ag04 at the moment so if for any reason there's a problem with that gateway you'd have to switch back to your normal username.
Plusnet Technology
25-06-2009 6:33 PM
25-06-2009 8:52 PM
