IPProfile dropping
gwillym
IPProfile dropping
When I upgraded to the 80/20 package some time ago, my IPProfile varied between about 57 & 63 Mbps during the training period and actually stabilised at about 57 for a while - given that i have an old piece of wet string between me and the cabinet (which i still can't locate :-) ) I thought that was quite acceptable, but since then it has been dropping so that now its only 42Mbps. So I'm only getting 2/3rds of the service I was expecting
Raising a fault has not helped to solve the problem - BT say its acceptable. Not to me it isn't.
How/why does an IPProfile deteriorate? As far as I can see its got nothing to do with the kit I have this side of the faceplate, so it must be somewhere in the BT network.
anyone got any explanation?
thanks in advance
Neil
Fixes: 78
Re: IPProfile dropping
An IP profile can decrease due to a number of factors. The main ones we would tend to see are either a drop in the sync speed of the line (perhaps due to a line or an exchange issue) or a due to multiple disconnections. It looks like the latter certainly hasn't been the problem in your case.
I've had a look at the fault and I don't know if you've interpreted our last reply this way but we're not saying there's nothing we can do, I'm sorry if that's the way you took that.
The ticket is back with our faults team now and we should be able to get a new fault report raised with our suppliers as this is still an issue for you.
 Adam Walker
gwillym
Adam
thanks for that. And yes, I had interpreted the latest update as a' can't help' response.
good to hear your guys are still on the case
