IP Profile
- IP Profile
IP Profile
02-02-2012 6:26 PM
We've just moved to Plusnet (yesterday) after an eternity on Tiscali/TalkTalk, We're already seeing benefits in latency and streaming speeds.
However we are still on a up to 1mbps connection (dsl synch speed of 1152), not surprising as we've only just moved over; I was wondering if there was a way to reset our profile to see if things have improved since we first got broadband, or would this happen automatically as part of switching over.
The only reason I ask is that we were quoted an average speed of 5mbps when we switched over (not the highest reason for doing so, but a factor)
any tips would be appreciated
Re: IP Profile
02-02-2012 6:42 PM
If so you need to raise a ticket to move to MaxDSL
Re: IP Profile
02-02-2012 6:50 PM
I presumed that it was a limitation on the line - we're pretty far from the exchange, and when we first moved to this address and got broadband there was a squirrel issue which caused constant disconnects and poor QOS.
now as a noob with plusnet, to raise a ticket I just have to give them a ring, no extra cost etc?
Re: IP Profile
02-02-2012 6:59 PM
Alternatively give them a call on 0800 432 0200 or 0345 140 0200 (the latter one is useful if calling from a mobile where it is part of the included minutes)
Re: IP Profile
02-02-2012 7:05 PM
Thanks for your help Jim. I think I'll give them a ring tomorrow - speeds are fast enough compared to what we were on before, just nice to have an idea that we might be able to go faster still.
I'm quite looking forward to it; calling yorkshire instead of chennai should make communication a bit easier, not a huge amount, but enough.
Re: IP Profile
07-02-2012 9:17 AM
How are the speeds at the moment? If this is still an issue please raise a fault and give me a nudge: https://portal.plus.net/apps/kbdfaults
Re: IP Profile
09-02-2012 8:02 AM
We're still on a 1152 kbps synch speed, I raised a ticket - #51914270. and confused the ADSL2+ and ADSLmax products so I have clarified myself in the response.
The support agent has mentioned that the connection is intermittent - whilst it may be an issue, I don't think it's the key one, as I would expect it to have changed when we had the router connected and up for 4 days. I have been trying to keep the router on and stable as long as possible, but sometimes a reboot is unavoidable.
Re: IP Profile
09-02-2012 10:06 AM
cannot wait for the increased speeds, whilst it's fast at the moment, I can't help but think that my eyes will be like this -> in a few days time
Re: IP Profile
09-02-2012 12:44 PM
did another BT Speedtest and it says our IP profile is 1000kbps....
Download speedachieved during the test was - 799 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :1152 Kbps(DOWN-STREAM), 288 Kbps(UP-STREAM)
IP Profile for your line is - 1000 Kbps
Re: IP Profile
09-02-2012 1:48 PM
right the request to move the BT cap has been made, just got to wait for it to complete, they said it was going to be 4 hours or so (really impressive, when working for a certain bank doing their IT Support this was the turnaround time if an entire branch went down, so for one measly request this is really impressive)
Does anybody know if there is a way to provide feedback for the CS agents involved, I was going to update the ticket to reflect how impressed I have been, but it'll end up in their work queue again, and nobody wants that.
Re: IP Profile
09-02-2012 1:56 PM
Adam for example on http://community.plus.net/forum/index.php?action=pm;sa=send;u=278
Re: IP Profile
10-02-2012 11:02 AM
Should be fine on the ticket in all honesty (nice for the support team to read something positive every so often ) but if you want to drop any of us a PM or just post up here that'd be fine. PM would probably be best as unless an agent posts in the forums we'd rather keep their names out of here if possible, but thanks and it's great to know you're wanting to feed back positively - cheers!
Re: IP Profile
10-02-2012 4:06 PM
.... IT WORKS!
we've synched up at 7040Mbps, and we're getting 5Mbps Downstream - if you want to see the change I took a screenshot of the speedtest and attached it.
