IP Profile reset
- IP Profile reset
IP Profile reset
14-07-2012 1:38 PM
Engineer completed work yesterday but my profile is still stuck at 0.25Mb and it is capable of 7Mb usually.
Username- nic4999
Re: IP Profile reset
14-07-2012 1:45 PM
If you mean the current line speed and the BT speedtest gives the correct one I suggest either raising a ticket or phoning
14-07-2012 3:02 PM
Engineer called Friday morning but there has been no update since. Perhaps I'm expecting too much, but I don't think so.
14-07-2012 3:13 PM
What speed does your router say it is connecting at and how long does it say the connection has been up?
14-07-2012 4:15 PM
My current speed is 0.125Mb/s, engineer completed work at around 1pm Friday and I have left it since then. I am just concerned that there has been no update on my ticket and I have received no text,email,tweet or even smoke signal. I'd rather be fobbed off then ignored totally. I could try and phone of course but isn't the point of online assistance to avoid hanging on the phone forever.
14-07-2012 4:25 PM
14-07-2012 5:10 PM
Quote from: Nicb4999 My current speed is 0.125Mb/s
No idea what you mean by that - downstream sync speed reported by your router, IP Profile reported by the BT speed test, current line speed shown of the Plusnet portal or the result of running a speed test?
What I was asking for is the first. The full results reported by a BT speedtest would be useful.
14-07-2012 5:20 PM
0.01 Mbps
0 Mbps 0.25 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.01 Mbps
For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
Additional Information:
Your DSL Connection Rate :0.86 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.14 Mbps
14-07-2012 5:28 PM
14-07-2012 5:50 PM
What we need are speeds, attenuation and noise margin.
The reason is that you either still have a problem or the line has been banded
14-07-2012 5:57 PM
<snip>
ADSL
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 2432Kb 448Kb
Noise Margin 9 15
Output power(dBm) 124 199
Attenuation(dB) 34 16
jim:green unnecessary and personally identifiable bit removed mod:end
14-07-2012 6:03 PM
14-07-2012 6:05 PM
First the reported sync speed is much higher than that reported in the BT speedtest
Second with that attenuation you should be getting speeds of about 7Mb at least
Third as you are apparently on ADSL1 and possibly 20CN connection the line isn't banded
So a further question - between carrying out the BT speed test and getting these stats did you resync the router
Finally the line fault does not appear to have been fixed
14-07-2012 6:11 PM
Thanks for your time, I will hopefully get it sorted and report back what happened.
14-07-2012 9:26 PM
Should you need to swap anything around or reboot/resync, please use this method -
Do a Disconnect of your PPP Internet session with the ISP - you need to login to the modem/router interface and look for the Disconnect button to click on. On the Thomson modem/routers you will typically find it in the box marked Internet as shown here.
Now wait a few minutes, power down. Then wait 10 minutes (during this time swap any filters, modem/router, connect to test socket, etc. - it doesn't matter if you take longer than 10 minutes) and then power up again (You may need to login to the modem/router and click on Connect to re-establish the PPP Internet session). Check the stats immediately (The Noise Margin [SNRM] shown is usually the current Target Noise Margin).
I usually recommend you do this no more than 5 times in an hour, and then leave it alone for the rest of the day. Remember the reason for this procedure is to help prevent the exchange DLM from thinking you have a dropping connection (or a worse one than you may have).
