IP Address... how do i tell what it is?
- IP Address... how do i tell what it is?
27-12-2010 4:05 PM
anyone know or do I just have to wait until I get home and access the router from within the home network?
cheers
Ian C.
Re: IP Address... how do i tell what it is?
27-12-2010 4:12 PM
unless you have a fixed IP address, your router get a different one each time it connects
27-12-2010 4:17 PM
I've sent you a PM with your current ip address. Bear in mind should your connection reboot at any time this will change as it's dynamic.
Jojo
27-12-2010 4:22 PM
just got the message and it's right. many thanks, that's much appreciated
27-12-2010 4:35 PM
No worries, glad I could help. I would suggest using something like DynDNS. You can set it up from home and when you're on the move it tracks your ip address.
Jojo
27-12-2010 6:14 PM
27-12-2010 6:47 PM
DynDNS is the way to do this is future for dynamic IPs and many routers support this natively without needing to run any software on a PC on the internal network..
27-12-2010 7:37 PM
27-12-2010 11:31 PM
brain in gear before accessing internet would be very sensible.
anyway, thanks for the suggestions and help. I'm sorted now - it's all much appreciated
rgds
Ian C.
27-12-2010 11:32 PM
excellent stuff. thanks again
28-12-2010 12:21 AM
29-12-2010 8:43 PM
thanks again
Ian C.
