IP Address Conflict (Vista) - Plusnet run out of ideas! HELP!
- Re: IP Address Conflict (Vista) - Plusnet run out ...
- « Previous
- Next »
Re: IP Address Conflict (Vista) - Plusnet run out of ideas! HELP!
09-07-2013 3:55 PM
I'm staying wired for the moment so i can get my work done, but will try unplugging tomorrow and doing the 'delete 0.0.0.0' magic trick again on my wireless setting!
I really am so grateful pwatdon. I'm going to be emailing Plusnet customer support and directing them to this thread with the suggestion of a reward for you and all your effort. We shall see how far I get!
Message 46 of 48
(337 Views)
09-07-2013 6:48 PM
It's not our good old 'friend' bonjour is it ? http://support.microsoft.com/kb/970313
Message 47 of 48
(337 Views)
09-07-2013 7:52 PM
Quote from: swonky - Plusnet need to give pwatson a free month or something, he's saved them lots of tec time and a very angry me!
I am so grateful.
Quote from: swonky
Like
There is an uncomplimentary 'technical' term for some of what transpired which a less generous person than pwatson might have been tempted to use, I know I was tempted to refer to it.
Anyway, I'm glad you're now sorted
Edit: Corrected Strat in place of Jelv, apologies to those concerned
Message 48 of 48
(337 Views)
- « Previous
- Next »
