IE7 won't connect
- IE7 won't connect
IE7 won't connect
05-02-2008 12:23 PM
Hi
I only use IE if I have to, but though it used to connect OK, now it doesn't - I just get:
Internet Explorer cannot display the webpage
Most likely causes:
You are not connected to the Internet.
The website is encountering problems.
There might be a typing error in the address.
There's nothing wrong with the connection using other browsers.
I changed my account recently to one with a wireless router and have read that this can cause problems. However I have not seen here or elsewhere any solution to the problem - other than reverting to IE6 (but from the recent Newsletter Microsoft seem to want to prevent that).
Ideas welcome.
Most likely causes:
Ideas welcome.
Message 1 of 6
(1,417 Views)
5 REPLIES 5
Re: IE7 won't connect
05-02-2008 12:36 PM
If you have a look in Tools -> internet options -> Connections, make sure that the option to never dial a connection is ticked. It might also be worth checking the 'LAN settings' button - I believe by default nothing is ticked in this window.
If that doesn't work then try removing all temporary files, cookies etc.
Hope that helps, please let us know,
Message 2 of 6
(545 Views)
05-02-2008 1:18 PM
If you follow the instructions on microsoft's website, you should be able to sort the problem. http://support.microsoft.com/kb/926431
I've taken a few calls, since IE7 was forced onto us, with the same symptoms. Every issue was sorted by <Method 2> on that help page. Basically, it seems that once IE7 is installed, it somehow manages to assign a private IP address (169.x.x.x) to the NIC, instead of one assigned by a router's DHCP (192.x.x.x)
Hope this was of some help to somebody.
Message 3 of 6
(545 Views)
05-02-2008 2:51 PM
Hi
Thanks for the suggestions, but so far no luck:
The settings were already OK
Did that, but no difference.
The network diagnostic shows the connection is OK and just offers simple advice to refresh and check spelling - no IP Address is given so I can't use Advanced Method 2.
I've tried the router reset and may look at safe mode, disabling security, checking services, etc when I have the time to spare. However, the thought occurs that I've started using AVG anti-virus fairly recently and I wonder if there's any history of conflict with IE7 at all.
Back to Opera and Firefox to get on with life!
Message 4 of 6
(545 Views)
05-02-2008 2:54 PM
IE7 & 6 working fine here with AVG
Do you have a software firewall? If so, try disabling that and see if you get it going.
Try setting IE back to default config via the various default buttons on the internet Options pages. Especially the security, privacy and advanced tabs
Message 5 of 6
(545 Views)
05-02-2008 3:03 PM
I do and it was blocking IE!! Changed the setting and all seems fine.
Don't know why it blocked when it didn't used to or why I got no message asking if I wanted to give access- but at least it works now.
Thanks to all.
Thanks to all.
Message 6 of 6
(545 Views)
