I've got the wrong router! Can I flash it?
- Re: I've got the wrong router! Can I flash it?
01-11-2013 10:53 AM
Hi
I've just been connected up to fibre but Plusnet gave me an ADSL router, so I've got not broadband.
Can I do anything with the router - it a Technicolor
thanks
Nathan
thanks
Nathan
Message 1 of 7
(1,296 Views)
6 REPLIES 6
01-11-2013 10:55 AM
what makes you think it's the wrong router?
usually LAN port 4 is used for the fibre connection.
Message 2 of 7
(655 Views)
01-11-2013 11:08 AM
I can see that you've been in touch with our Support Team who have sent you out a FTTC router. If you wanted to, you can visit http://products.plus-payh.co.uk/firmware/ and change the firmware to FTTC if you'd like?
Message 3 of 7
(655 Views)
01-11-2013 11:24 AM
I've got a Apple Mac - will it run the tool OK?
Message 4 of 7
(655 Views)
01-11-2013 11:26 AM
No, it's windows only - you'll either need a vm, wine or crossover to attempt to run it.
If you're not sure what these are I'd wait for the new one to turn up
Message 5 of 7
(655 Views)
01-11-2013 11:31 AM
It's possible to update the firmware via TFTP http://wiki.aa.org.uk/Router_-_TG582N_-_Firmware_and_Factory_Reset but how you'd go about doing that on a Mac I've no idea I'm afraid
Message 6 of 7
(655 Views)
01-11-2013 2:03 PM
I think I'll take the advice to wait for the new router.
I know I'll spend half a day on this and still jigger it up.
thanks very much for the info though.
Message 7 of 7
(655 Views)
