I ( use to ) want to quit trial
James
Re: I ( use to ) want to quit trial
Ah, of course Smiley
scootie
Planned Router Maintenance - Monday 11th May 8.30am-9.30am.
Internet Connectivity
Posted on: Friday 8 May 2009, 09:25
When's this work happening?
Monday
What does it affect?
Customers on our 21CN trial.
How long will it take?
About thirty minutes.
What does the work involve?
We are making some changes to the host link on this trial.
Is it likely to cause problems?
Yes, all 21CN trial customers will be disconnected for a brief period during this maintenance. All customers should be able to reconnect straighaway.
Is there anything else I need to know?
No.
this tinkering with the host link anything to do with solving the latency issue?
James
Nope, nothing to do with that.
It's to enable our IPStream Connect trial.
scootie
yep just found that out after googling Smiley  50 p a meter rental charge.
any idea what time the extra bandwidth will be live?
James
At some point today Wink
It's not been completed yet.
scootie
just hope the 10-21mb sync'ers havent got loads of thoughput spare that will eat the new bandwidth up straight away Smiley i like the sounds of the platinum Wink
dave
Fixes: 4
Still waiting for BT to complete it... Will recheck later when I get home to see if it's been done and apply the change our side.
Dave Tomlinson
Plusnet Technology
scootie
bang on midnight and i got signed out of XBL i could sign back in but that shows you how bad packet loss and latency is when the rate limits are raised , checked my pings shocking .
you seem to have calmed down latency when rates change at 10, 11 but midnight i just dont think traffic mangment was ever designed to handle 21mb thoughput and goes into melt down when everything is at line speed
i so want to stick this out till you fix things but not being able to game during some of gamings prime time midnight-2am is killing me
scootie
geting low and stable ish now at just before 2am.
when they started to drop and stablize bettween1 -2am i dont know but just before 1am they where averaging at 30-40 and spiking at 150ish as the guys on iirc will tell you as i tried to play top trumps with ping times with them not knowing they were all on the trial
if you could get latency to these levels at midnight- 1am. then i would disapper back in to my box(an x shapped one) never to annoy you guys again Smiley
SEWERWOLF
Quote from: ASBO
any one got a pic of werewolf to put on this one.
2am and still not back to normal.
this is last ping result iam posting if i go another weekend with this latency i will be looking else were for better latency so i can start gaming again.
Hence why i opted for virgins XXL 50meg package
scootie
its a trial serwolf.
i had no problems for the past 2 years and even if it was a case of stuck on trial or move to a new provider i wouldnt touch virgin with a barge pole
and when say things like that in this thread it's just the red mist at that moment. i come to my senses in the morning and remember why i moved to plusnet 2 years ago Wink
dave
Fixes: 4
Bandwidth increase has been done, let's see what effect it has...
Dave Tomlinson
Plusnet Technology
scootie
dave did the bandwidth get lit on satarday.
as gaming was fine till midnight but i jumped off thinking it's going to lag any way and jumped back on to cod waw at 00.45 and the lag meter was 4 bars and i was host for a full hour that played it. Smiley
looking at the packet drop graph i would of thought i would of seen lag in the afternoon of satarday but didnt. was messing about with windows 7 rc last night so didnt get round to doing any pings.
did you do any more tweaking or was satarday a fluke?
EDIT.
i think this would be the reason latency is gd at the mo http://community.plus.net/forum/index.php/topic,76296.0.html
scootie
Smiley Smiley Smiley
alot better
iam not sure if the major packet loss is down to a resync i just did that got the same sync speed as one done midday Crazy http://community.plus.net/forum/index.php/topic,75667.msg612229.html#msg612229
i will try and force the DLM into thinking ive got a line fault and get it to drop sync speed and see if the packet loss is still there
scootie
k i dropped my sync rate and packet loss is still there i also went on iirc to ask be3g to check  and there's packet loss on his line to.
