I think my exchange now has 21CN..
- I think my exchange now has 21CN..
- « Previous
- 1
- 2
- Next »
Re: I think my exchange now has 21CN..
02-03-2012 9:20 AM
02-03-2012 3:07 PM
Sorry and thanks again Adam.. I seen the ticket you raised has been closed with the date showing the 8th..
Is it worth or possible to uncap the upload as I only ever get around 336 my son play alot of online games via pc and ps3 and also watches / uploads to youtube..
02-03-2012 4:29 PM
If it's not been requested to uncap on the order we can do it within 24 hours once it's complete.
Jojo
02-03-2012 4:39 PM
I’m starting to panic that my Netgear DG834GT with the latest firmware v 1.03.23 isn’t going to work on ADSL2+
The box says ADSL2+ modem however I can’t find anything on the Netgear support site to back this up nor can I see any settings which show this option within the router configuration page..
Do you know anyone who has this router on ADSL2+ and if so do I need to change any settings or will it automatically know the change has taken place?
I do still have the TG585v8 router however I’m currently using this as an access point as the DG834GT seems to give better sync speed and wireless signal in my house but if it comes down to it I guess I’ll have to swap them round..
Is it worth staring a new thread?
02-03-2012 4:47 PM
02-03-2012 4:54 PM
02-03-2012 4:56 PM
its there ,
if its on default it will connect fine
02-03-2012 4:59 PM
Could it be Multiplexing Method I have 2 options VL or LLC
02-03-2012 5:03 PM
look around in there for Modulation mode
but if you have updated the firmware and not changed it it should be set to default anyway (so will work fine)
06-03-2012 4:32 PM
06-03-2012 5:04 PM
06-03-2012 5:09 PM
I've been reading the line setup guide and it says during the 10 days it will help if you reboot the router a few times in the morning so I was thinking leave it until the 10th and do a reboot around 11 am and them again on the 12th 15th and 17th does that sound about right?
06-03-2012 5:38 PM
Unless you have reason to believe noise margin is higher than it needs to be I suggest doing one restart after 4 or 5 days (so the DLM will have seen a stable connection) and leave it at that. You might find the DLM tries different target noise margins and interleaving settings itself.
- « Previous
- 1
- 2
- Next »
