I have FTTC but account says I have Plusnet Extra
- Re: I have FTTC but account says I have Plusnet Ex...
13-05-2011 11:06 PM
Can a member of staff please fix this.
Re: I have FTTC but account says I have Plusnet Extra
14-05-2011 10:31 AM
I had it installed yesterday and I am also only receiving 10Mb speed, when I was given an estimate of 35Mb for my area. I was told it takes up to 24 hours to get the right speed, but I am worried that I am only getting this because plusnet have not changed my order yet.
16-05-2011 10:44 AM
Seems this has been rectified now and your account is showing the correct usage. Just to let you know, although we sometimes come on the forums over the weekend, we only officially monitor them Monday to Friday 9.00am - 5.30pm.
Jojo
16-05-2011 12:42 PM
I have another problem. I am having problems with the new Netgear router. I am having trouble connecting to it from some devices. It connects just fine to my laptop, but I have a Technika Smartbox 8320HD box, and it cannot connect to the Netgear router. It will connect to my old router but just will not connect to the Netgear one. I contacted FetchTv who the box belongs to, and they said I would need to contact plusnet. I have tried changing many settings in the router configurarion, such as mode, channel, l also disabled the encryption but it still would not connect, even when I disabled WPS.
16-05-2011 4:17 PM
Have you made sure UPnP is enabled on the router? It's in the advanced section on the router interface.
Jojo
16-05-2011 6:51 PM
16-05-2011 7:09 PM
17-05-2011 12:32 AM
17-05-2011 12:02 PM
Is it a wired or wireless connection? When you say it can't connect, do you get a message, how do you know it's not connected. I guess what I'm trying to say is can you give me as much information as you can; what you're doing, how you're doing it, what have you tried. That kind of thing.
Jojo
26-05-2011 7:31 PM
I have tried changing the channel, changing the SSID, changed the encrypted key and disabled the encrypted key.
28-05-2011 12:23 PM
I simply downgraded the firmware of the router to a previous version and it worked straight away.
Still having speed problems but that is being resolved by someone else.
Thanks for your help
