Huge packet loss on specific destinations
- Huge packet loss on specific destinations
Re: Huge packet loss on specific destinations
06-01-2014 8:55 PM
06-01-2014 9:00 PM
06-01-2014 9:03 PM
06-01-2014 9:09 PM
looking at logs pasted, it's not PlusNET's network causing the timeouts. Give them time, sure they are contacting providers regarding this. Don't expect things to be fixed instantly, when other providers maybe working on this.
07-01-2014 1:10 PM
Is anyone in contact with Proxad? I am not able to contact them due to them only speaking to members (and being French it would seem?).
07-01-2014 1:27 PM
Monday was better but still rough. Correction: the trace I did was from Monday evening.
This is the trace I posted in a ticket:
See hops 5 and 6, it seems to take an excessive time and drop packets
01/06/14 20:50:18 Fast traceroute 195.154.168.239
Trace 195.154.168.239 ...
1 192.168.3.254 2ms 2ms 1ms TTL:255 (my.router bogus rDNS: host not found [authoritative])
2 195.166.128.193 19ms 19ms 43ms TTL:126 (lo0-central10.ptn-ag04.plus.net bogus rDNS: host not found [authoritative])
3 212.159.2.142 19ms 19ms 18ms TTL:250 (link-b-central10.ptn-gw02.plus.net bogus rDNS: host not found [authoritative])
4 212.159.0.118 18ms 18ms 35ms TTL:252 (xe-8-2-0.ptw-cr02.plus.net fraudulent rDNS)
5 195.166.129.4 18ms 19ms 19ms TTL:252 (ae2.ptw-cr01.plus.net bogus rDNS: host not found [authoritative])
6 195.66.224.191 * 91ms 103ms TTL:251 (linx-6k-1.routers.proxad.net ok)
7 212.27.51.185 100ms 98ms 99ms TTL:250 (bzn-crs16-1-be1102.intf.routers.proxad.net ok)
8 212.27.58.50 101ms 98ms 98ms TTL:245 (dedibox-2-t.intf.routers.proxad.net ok)
9 88.191.1.131 * * 101ms TTL:245 (a9k1-1012.dc3.poneytelecom.eu bogus rDNS: host not found [authoritative])
10 88.191.1.178 * 100ms * TTL:247 (45x-s44-1-1039.dc3.poneytelecom.eu bogus rDNS: host not found [authoritative])
11 195.154.168.239 * 98ms * TTL: 55 (195-154-168-239.rev.poneytelecom.eu ok)
12 195.154.168.239 105ms TTL: 55 (195-154-168-239.rev.poneytelecom.eu ok)
For comparison I tried the same destination mid afternoon and the results were much better:
01/07/14 13:47:19 Fast traceroute 195.154.168.239
1 192.168.7.254 0ms 0ms 0ms TTL: 0 (my.router bogus rDNS: host not found [authoritative])
2 195.166.128.193 29ms 31ms 29ms TTL: 0 (lo0-central10.ptn-ag04.plus.net ok)
3 212.159.2.142 28ms 28ms 29ms TTL: 0 (link-b-central10.ptn-gw02.plus.net ok)
4 212.159.0.118 28ms 30ms 28ms TTL: 0 (xe-8-2-0.ptw-cr02.plus.net ok)
5 195.166.129.4 28ms 28ms 30ms TTL: 0 (ae2.ptw-cr01.plus.net ok)
6 195.66.224.191 28ms 28ms 28ms TTL: 0 (linx-6k-1.routers.proxad.net ok)
7 212.27.51.185 35ms 36ms 38ms TTL: 0 (bzn-crs16-1-be1102.intf.routers.proxad.net fraudulent rDNS)
8 212.27.58.50 36ms 36ms 38ms TTL: 0 (bzn-crs16-1-be1102.intf.routers.proxad.net fraudulent rDNS)
9 88.191.1.131 36ms 36ms 36ms TTL: 0 (a9k1-1012.dc3.poneytelecom.eu ok)
10 88.191.1.178 39ms 36ms 43ms TTL: 0 (45x-s44-1-1039.dc3.poneytelecom.eu ok)
11 195.154.168.239 36ms 35ms 36ms TTL: 52 (195-154-168-239.rev.poneytelecom.eu ok)
07-01-2014 1:29 PM
Ex-Broadband Service Manager
07-01-2014 1:58 PM
07-01-2014 5:05 PM
07-01-2014 5:09 PM
Quote from: oruvin Kelly,
As I see you have no packet loss, BUT you have different PlusNET router (ae1.ptw-cr01.plus.net) connected to the RETN network, my route is going through ae2.ptw-cr01.plus.net router. Maybe there is problem with PlusNET router (ae2.ptw-cr01.plus.net)?
That's the same router, just a different interface. Aggregated Ethernet 1 and 2 on Plusnet router ptw-cr01.
07-01-2014 6:59 PM
Packet loss currently at 5% on 100 ping count to dj.virtualdj.com, I expect it to worsen in the next hour or so.
07-01-2014 7:22 PM
Interestingly there doesn't seem to be an issue over their IPv6 peer.
07-01-2014 7:33 PM
As you can see there's a big jump in response time at proxad
01/07/14 19:27:10 Fast traceroute 195.154.168.239
1 192.168.3.254 2ms 1ms 1ms TTL:255 (my.router bogus rDNS: host not found [authoritative])
2 195.166.128.193 20ms 28ms 24ms TTL:126 (lo0-central10.ptn-ag04.plus.net bogus rDNS: host not found [authoritative])
4 212.159.0.118 19ms 38ms 20ms TTL:252 (xe-8-2-0.ptw-cr02.plus.net fraudulent rDNS)
5 195.166.129.4 21ms 20ms 19ms TTL:252 (ae2.ptw-cr01.plus.net bogus rDNS: host not found [authoritative])
6 195.66.224.191 89ms * 96ms TTL:251 (linx-6k-1.routers.proxad.net ok)
7 No Response * * *
8 No Response * * *
9 88.191.1.131 101ms 100ms * TTL:245 (a9k1-1012.dc3.poneytelecom.eu bogus rDNS: host not found [authoritative])
10 88.191.1.178 * 103ms 102ms TTL:247 (45x-s44-1-1039.dc3.poneytelecom.eu bogus rDNS: host not found [authoritative])
11 195.154.168.239 99ms * 98ms TTL: 55 (195-154-168-239.rev.poneytelecom.eu ok)
Retested a few minutes later:
01/07/14 19:34:21 Fast traceroute 195.154.168.239
1 192.168.3.254 1ms 1ms 1ms TTL:255 (my.router bogus rDNS: host not found [authoritative])
2 195.166.128.193 19ms 19ms 20ms TTL:126 (lo0-central10.ptn-ag04.plus.net bogus rDNS: host not found [authoritative])
3 212.159.2.142 18ms 18ms 20ms TTL:250 (link-b-central10.ptn-gw02.plus.net bogus rDNS: host not found [authoritative])
4 212.159.0.118 18ms 17ms 19ms TTL:252 (xe-8-2-0.ptw-cr02.plus.net fraudulent rDNS)
5 195.166.129.4 19ms 18ms 18ms TTL:252 (ae2.ptw-cr01.plus.net bogus rDNS: host not found [authoritative])
6 195.66.224.191 19ms 19ms 19ms TTL:251 (linx-6k-1.routers.proxad.net ok)
7 212.27.51.185 28ms 33ms 30ms TTL:250 (bzn-crs16-1-be1102.intf.routers.proxad.net ok)
8 212.27.58.50 28ms 28ms 28ms TTL:245 (dedibox-2-t.intf.routers.proxad.net ok)
9 88.191.1.131 25ms 28ms 26ms TTL:245 (a9k1-1012.dc3.poneytelecom.eu bogus rDNS: host not found [authoritative])
10 88.191.1.178 35ms 29ms 32ms TTL:247 (45x-s44-1-1039.dc3.poneytelecom.eu bogus rDNS: host not found [authoritative])
11 195.154.168.239 26ms 35ms 30ms TTL: 55 (195-154-168-239.rev.poneytelecom.eu ok)
07-01-2014 9:07 PM
07-01-2014 9:48 PM
I tried traceroutes from three other UK networks/sites and they all go through Linx.
