Hub One Router - Connecting a Mesh Router
- Hub One Router - Connecting a Mesh Router
06-04-2020 6:29 PM
I have a Plusnet Hub One Router and have just bought a Gryphon Mesh router - I have been advised by Gryphon that as I am unable to connect the Gryphon directly to the wall jack, I have to connect an ethernet cable to either 1 through 4 on the Plusnet, to the Internet connector on the back of the Gryphon. However, when I do this, the Gryphon does not receive signal. Is there anything I need to do to the Hub One to enable this setup?
Re: Hub One Router - Connecting a Mesh Router
07-04-2020 11:20 AM
@Sharky666 Welcome to the forum.
You should switch off the Hub One wireless but more importantly the Gryphon should be set up as an Access Point, not a router.
07-04-2020 2:47 PM
Thanks I'll give that a go
02-05-2020 3:18 PM
There's either another setting that I'm overlooking, or this PLUSNET router is not the best device to use for the purpose of using the Gryphon and needs replacing.
