How to tell if you're really on an ADSL2+ enabled line ?
- How to tell if you're really on an ADSL2+ enabled ...
Re: How to tell if you're really on an ADSL2+ enabled line ?
11-03-2010 11:09 AM
@colbrad I believe CParr is looking at your account now.
11-03-2010 11:13 AM
11-03-2010 11:25 AM
www.mybroadbandspeed.co.uk now tests at 12429 down and 743 up - Awsome!!
Cheers
Mark
11-03-2010 11:29 AM
DATE / TIME DOWNLOAD UPLOAD
11/03/10 11:23 5685.29 Kbps 250.15 Kbps
11/03/10 11:21 5030.94 Kbps 293.85 Kbps
11/03/10 11:16 5692.24 Kbps 282.91 Kbps
is there a delay before my speeds will start to increase / or a gradual improvement or should there be a significant improvement already
11-03-2010 11:32 AM
11-03-2010 12:05 PM
still not hit the 9000 figure yet, is there anything else I can do / tweaks etc to improve the speeds, thanks
11/03/10 11:59 8118.31 Kbps 367.05 Kbps
11/03/10 11:53 7816.61 Kbps 368.24 Kbps
11/03/10 11:50 8053.33 Kbps 368.72 Kbps
11/03/10 11:45 7723.60 Kbps 362.28 Kbps
11/03/10 11:43 7325.51 Kbps 327.11 Kbps
11/03/10 11:42 7956.62 Kbps 344.54 Kbps
11/03/10 11:41 6878.18 Kbps 351.15 Kbps
12-03-2010 2:16 PM
Any chance you could nudge my profile also ::). My router is sync'd at 16,399 and my BT profile is 14,000.
Current download speeds between 5 and 6.5 Mbps.
Many thanks
Richard
13-03-2010 1:18 AM
Bandwidth (Up/Down) 443 / 11,499
Plus something I've noticed in my TBB connection details that I'm a little confused about is the KEMPTOWN ( SDKMPTW ) exchange, as theres not an option to change the exchange to SHARROW, only the postcode which is currently correct... So, stupid question here, am I really connecting through an exchange over 200 miles away
Connection Details
Description My home DSL
Package Name MAX Broadband Premier 50GB
ISP Name Madasafish
Telephone No. 0114*******
Monitor IP 91.125.69.**
Postcode S2 ***
Exchange KEMPTOWN ( SDKMPTW )
13-03-2010 1:43 AM
The BT list has been known to have the wrong details entered, but that shouldn't affect the service.
13-03-2010 2:02 AM
thanks for the reply, the checker is saying SHARROW exchange, which is less than half a mile away...
13-03-2010 1:38 PM
13-03-2010 2:56 PM
Uptime: 0 days, 14:15:02
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 443 / 11,499
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 18.0 / 35.5
SN Margin (Up/Down) [dB]: 28.5 / 6.5
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 18 / 0
FEC Errors (Up/Down): NA / 0
CRC Errors (Up/Down): NA / 1,601
HEC Errors (Up/Down): 0 / 918
my current download speeds are averaging around 7.5meg
DOWN UP
7477.29 Kbps 365.61 Kbps
7449.87 Kbps 347.06 Kbps
7466.66 Kbps 337.54 Kbps
7370.09 Kbps 365.21 Kbps
7901.61 Kbps 368.73 Kbps
7965.89 Kbps 368.75 Kbps
14-03-2010 9:18 PM
DOWN UP
1090.34 Kbps 363.48 Kbps
1588.58 Kbps 365.94 Kbps
1414.59 Kbps 367.28 Kbps
14-03-2010 11:02 PM
The speed you actually see on speed tests is controlled by your IP Profile which you can find out from a BT speed test at http://www.speedtester.bt.com, and your Plusnet profile which should duplicate the one set by BT. For Plusnet customers this is shown as Current line speed in the Member Centre, but I don't know if and where it is shown for Madasafish customers. For sync at 11499kbps both values should be 10000kbps.
Getting results from the BT speedtester can be troublesome at times, but persistence usually pays off.
15-03-2010 11:51 AM
@rgschofield, I've updated your profile and replied to your ticket.
@colbrad, I've made a couple of changes to your account, can you retest for me please?
