How to remove errors registered on my line
- How to remove errors registered on my line
Re: How to remove errors registered on my line
20-06-2012 2:59 PM
That shows it was loss of Wireless connection for some reason as your PPP session didn't drop.
Now it's possible that drops in wireless may be caused by outdated drivers or interference on the channel being used, so both avenues are worth checking out.
20-06-2012 5:13 PM
Cant even play my Xbox at the minute.. nice!
I took this test when I was wired
20-06-2012 7:02 PM
run the BT Speedtester (Diagnostic)
What are the current Noise Margin graphs like?
20-06-2012 7:27 PM
LURGAN
Estimated line speed:
6Mb (This may vary between 5Mb and 8Mb) - Checked on 2012-05-25 23:52:51
Current line speed:
37 Mb
No idea why it says 37mb. And I couldn't run the standard speed test so I ran the beta instead.
20-06-2012 7:46 PM
Also check out what is happening on the Wireless channel that you are currently using. There maybe someone else local to you using the same channel and that could be the cause of your losses of connection. You can change wireless settings without having to reboot the Billion.
Make sure your wireless is secure WPA2-PSK with a strong password that is not a dictionary word, a mix of letters, numbers and other characters.
20-06-2012 8:17 PM
20-06-2012 9:31 PM
21-06-2012 1:06 AM
21-06-2012 9:37 AM
When noise is present, it isn't necessarily something that is equally distributed across all the frequencies used by the broadband signal. It could be more severe at some frequencies which will cause corruption of some bits of data, this is seen as errors. Error correction causes the corrupted data to be retransmitted and it's such retransmission that can cause some lag and lower throughput speed.
I hope that's given you a clearer picture.
So when you switch something on that's generating a lot of noise the noise margin goes down, in this case from 9 to 6dB (approx). Correctly designed and functioning equipment shouldn't generate as much noise as appears to be happening here. Once you known where it's coming from, then steps can be taken to suppress, filter or perhaps repair the offending item. Sometimes just re-arranging where all the connecting leads are in relation to other leads can reduce or eliminate a problem - but not always.
I hope that explanation helps.
21-06-2012 11:13 AM
It is still around 9 but dropped to 6 again at around 6:55am to 7:05am (I kept it on all night this time)
21-06-2012 11:17 AM
21-06-2012 1:57 PM
21-06-2012 2:08 PM
Keep an ear on it, so to speak.
21-06-2012 3:24 PM
21-06-2012 10:39 PM
