How to get max speed?
- How to get max speed?
Re: How to get max speed?
28-10-2014 9:07 PM
SNR Margin
1.1 16.6 db
Line Attenuation
59.5 39.3 db
Data Rate
3346 445 kbps
Max Rate
3436 828 kbps
CRC
4764 0
28-10-2014 9:21 PM
Also something odd happened just after 1636, it looks as though the graph stopped and when it started circa 10 minutes later the SNRM was nearly 2dB higher - maybe there was a drop then, but why the 10 minutes gap
28-10-2014 9:49 PM
28-10-2014 10:14 PM
When you next try to upgrade the firmware, once you have it downloaded, I would disconnect from the line so any re-boots are done off-line and you can check all is OK before going back on-line.
28-10-2014 10:35 PM
Quote from: Anotherone Ah, OK, understood.Which version of the modem/router is it by the way?
TD-W8961ND V3
FW Version: 3.0.0 Build 120808 Rel.28888
Latest version appears to be 140305 but doe some reason it won't work.
Thanks for the tip, I shall do.
29-10-2014 8:51 AM
29-10-2014 10:03 AM
But this which has been trundling along so close to 0 is somewhat unusual. What's the current CRC figure?
Quote from: Steevo TD-W8961ND V3
I assume you will wait (it would be best) until you hear back from TP Link.
29-10-2014 10:35 AM
Stats as follows. There was a line drop around 9am this morning which likely reset it.
Downstream Upstream
SNR Margin
2.5 16.9 db
Line Attenuation
59.5 39.2 db
Data Rate
3488 445 kbps
Max Rate
3572 844 kbps
CRC
360 0
29-10-2014 10:56 AM
29-10-2014 11:04 AM
29-10-2014 11:18 AM
29-10-2014 11:29 AM
29-10-2014 11:42 AM
29-10-2014 10:34 PM
29-10-2014 10:35 PM
