How to display the router home page
- How to display the router home page
- « Previous
- Next »
Re: How to display the router home page
14-07-2011 1:05 PM
Sounds like the network interface on the laptop may be preconfigured with a static IP (or locked down from connecting to new networks using DHCP), could that be the case? That way any new network wouldn't actually configure itself to work properly, hence why you get no connectivity.
Not sure how that then works with the VPN software, unless that's what is controlling the network's autonconfiguration? Might be worth asking the IT team at your workplace how it's all set up if that is the case, just a possibility though.
Message 46 of 53
(499 Views)
14-07-2011 2:03 PM
Matt - I was thinking on the same grounds as you. I even tried uninstalling the network drivers and reinstalling them but to no luck.
What puzzles is I am not sure where this block has been done as I have tried all the possible places to look.
My work place IT help desk have been very supportive as they have not come across this problem before with any other office colleague.
jim:quote
jim:quote
Message 47 of 53
(499 Views)
15-07-2011 9:27 AM
Apologies if you've tried this, but if you run an ipconfig /all command from a command prompt both with and without the VPN software running what is shown?
Just wondering what IP addresses you get, if any (best to have a network cable plugged into the laptop for this).
Another thought is if firewall software might be blocking traffic on any 'untrusted' (i.e. new) networks.
Message 48 of 53
(499 Views)
15-07-2011 11:18 AM
Quote from: Matt Apologies if you've tried this, but if you run an ipconfig /all command from a command prompt both with and without the VPN software running what is shown?
Hi Matt
I have connected the laptop through a network cable to the router
With or Without VPN, when you do ipconfig / all, I get the Default Gateway as 192.168.1.254 (which belongs to the router) along with my PC's IP address.
Message 49 of 53
(499 Views)
15-07-2011 1:47 PM
Understood, but was the IP the same in both situations and was it also on the same subnet as the router (i.e. in the format of 192.168.1.x)? If so it would seem that something is stopping all network traffic apart from that of the VPN.
Message 50 of 53
(499 Views)
16-07-2011 10:14 AM
Hi
I have bottomed out where the issue is. It is something to do with the THOMSON router for sure
Reason : I took my laptop and connected it at my friends place. I was able to access the internet / router page without having to connect to AT&T
I will try with my router at home again to see if I can connect it again without the use of AT&T / VPN path.
In the meantime, does anyone had similar issues in bringing up the router from Plusnet THOMSON ones?
dick:quote
dick:quote
Message 51 of 53
(499 Views)
18-07-2011 10:36 AM
I have tried once again with my THOMSON router @ home (PLUSNET) and I have this issues in connecting to Internet / router directly.
When I tried the same at my friends place who has a BELKIN router & with a different provider, I am able to access the internet / router without any issues.
So , does this mean that the THOMSON router is preventing something to access the internet / router directly as its getting strange now.
I have tried it through network cables and in every single network port on the THOMSON router.
Any thoughts will be really helpful
jim:quote
jim:quote
Message 52 of 53
(499 Views)
18-07-2011 10:48 AM
It does not necessarily mean this is the Thomson router. When Windows (and possibly other software on your computer) detects a new network it will establish settings for the network and may ask questions. If you give the wrong answer to the questions or the security software gets it wrong then you might just find yourself in this situation. You need to invite your friend and their laptop over to your place to see if they can connect to your router and to the internet.
Message 53 of 53
(499 Views)
- « Previous
- Next »
