How to be rid of the Ticket Reply Notification
- How to be rid of the Ticket Reply Notification
24-03-2009 6:51 PM
I have Auto Login turned on and set to 2 years although a quick look just now it appeared to off although I am still automatically loged in after a reboot. I have reset it anyway but this has been happening for around 2/3 weeks now and I had reset Auto Login last week anyway after deleting the PN cookie in error.
Edit: Just moved away from the Auto Login page then clicked on the Auto Login icon on the Connection Settings page and the Auto Login is shown as off again. Should it not be showing as on/activated or has it always behaved in this way? Not sure as I have never gone to this page to check it's on but just to turn it on after the cookie has been deleted (used to happen after running a Spybot S & D scan until I found you could ignore selected cookie :-[).
It would be nice if there was a message to clearly indicate it was on and what the time setting is.
Forum Moderator and Customer
Re: How to be rid of the Ticket Reply Notification
24-03-2009 8:58 PM
reply to a ticket, but when clicking the box it is with regards to a ticket reply you have already read previous, and there is no new reply to other tickets.
Regards
Mike
Quote from: Mav Everytime I first log into the Member Centre Home page there is a yellow box informing me that there is a response to a ticket. I have tried clicking the link to read it many times (It's the same reply each time) and clicking the Close icon but each time I reopen the home Member page usually after a reboot the notification is back.
24-03-2009 9:35 PM
Quote from: Mav ...usually after a reboot the notification is back.
I've found just opening the home page within a new instance of IE and it's back even though the home page (without the notification) is still open in the other instance.
25-03-2009 7:44 AM
25-03-2009 8:17 AM
Have you tried any other browsers just to make sure its not Internet explorer playing up???
25-03-2009 9:09 AM
25-03-2009 9:19 AM
Some ticket responses are for information and do not require a response from the customer. As a customer, what we want is to know if any new information has been added to the ticket since the last time it was read, but the portal notification still appears each time you log on if the ticket is still open but nothing has happened. This can be annoying if you have a long-running problem ticket open and expect the notification to appear only if some progress has been made.
25-03-2009 10:03 AM
That also guarantees that the ticket doesn't get closed due to inactivity.
25-03-2009 1:41 PM
Smart reply, as this was bothering me also. I'll follow your recommendation in future.
25-03-2009 3:09 PM
25-03-2009 3:11 PM
25-03-2009 3:41 PM
25-03-2009 3:58 PM
Quote We would like to inform you that your Help Assistant Question [ 28134932 ] has now been returned to the BOT - Simultaneous Provides pool. A member of our Support Team will investigate your issue as soon as possible.
from Script User Automated Script Pool
To be honest I did feel a little silly giving a reply to an automated message - bit like saying 'thank you' when you take your cash from an ATM
Edit: It has stopped the notification from appearing, though.
25-03-2009 6:06 PM
Quote from: pierre_pierre how do I get rid of the referral note then
I've noticed the same thing.
I don't log in very often, and when I do it's not been sufficiently annoying enough for me to try and do anything about it.
Which is most unusual for me - any prompt or notification usually does.
I suppose you could get PlusNet to remove the referrals, but that probably isn't the solution you're looking for
26-03-2009 12:10 AM
