How much difference would you expect from the Master Socket?
gwowders
Hi all,
I'm having some problems with my connection at the moment so have been trying to verify on the Master Socket before calling anyone.  I noticed that my Data Rate (line speed?) is significantly higher in my master socket than into the faceplate, which is perhaps to be expected, but I was amazed at how much of a difference it made.
Before (in the face plate)
Data Rate 1536Kb (down) | 448Kb (up)
Noise Margin 13 | 18
Output Power 123 | 170
Attenuation 58 | 31
After (Master Socket)
Date Rate 2752Kb | 448Kb
Noise Margin 12 | 19
OutputPower 122 | 188
Attenuation 58 | 31
Does it really make that much of a difference to my downstream Data Rate or does it look like my faceplace is a little suspect?  In which case, would anyone recommend one of these - http://www.clarity.it/telecoms/adsl_faceplate.htm ?Huh
The issue that I am looking into is a slow (over the course of a few hours) degredation of my line speed followed by disconnection.  The line actually sounds quite noisy at times as well.  I've noticed some BT chaps doing a fair bit of work around my area of late so could easily put it down to them but want to be absolutely certain its not my kit first!!  So far I've replaced the filter but it's made no difference.
All thoughts appreciated.
Ben
Fixes: 62
Re: How much difference would you expect from the Master Socket?
That sounds like your internal wiring is a problem - that is the wires attached to the removable faceplate
If you line is noisy then report it to your voice supplier but don't mention broadband.
However make sure you can hear the noise when using the test socket - if you can't it's your internal wiring again
gwowders
If it was my wiring would you expect the line to be noisy all the time?
I'm currently connected back to the faceplate (as normal) and the line is quiet, the broadband connection seems stable and the line speed is healthy.
Can a wiring fault on the faceplate be that intermittent?
Do you have any experience of that alternative faceplate that I linked to as well?
Ben
Fixes: 62
No - I use the ADSLNation http://www.adslnation.co.uk/products/xte2005.php
Do you have any wires connected to the removable faceplate or is that the only socket in the property
198kHz
Aspiring Champion
Fixes: 13
Quote from: gwowders
FWIW, I've got a fair run of extension wiring, and have found no difference in performance between the Clarity and ADSLNation faceplate - both excellent.
Remember you are unique - just like everyone else
gwowders
The ADSLNation one is cheaper, perfect!
Currently I am wired up as follows. 5 m. extension cable from BT socket to ADSL filter, DSL line off to my modem and a splitter to take my phone and Sky lines.  This has been the same setup for several years so I'm not too concerned about it (although I appreciate that the extension cable won't help my connection speed).
gwowders
Cheers Force E!
198kHz
Aspiring Champion
Fixes: 13
Also found ADSLNation to be very efficient dispatchers, and Clarity very slow.
gwowders
I'd just ordered from ADSL Nation actually, so thats good then!
HaydnExport
the difference could be that you put it into the master socket when there is a good signal from the exchang (10am to 3pm, 2pm i find best)  , and the previous dsl speed was due to a disconnect or reeboot in the evening / night.  I would try the faceplate again around 2pm , then you will see if it worth splashing the cash !
gwowders
Thanks HaydnExport.
I tried the master socket at about 6ish last night, not sure if that's a good time or not then!!
gwowders
Update:
ADSL Nation faceplate installed and *initially* things looked amazing - a line speed of c.2700Kb which is unheard of.  Problem is, the connection reset a few hours later and I'm now back down to 416Kb again.  I just dont get it!!!  Undecided
I'll try a different modem and dsl cable in a bit just to make sure but I really cant see it...
Any more thoughts from anyone?
Fixes: 62
Try disconnecting the Sky lines
gwowders
It already was disconnected oldjim!  Sad
gwowders
Here's a weird observation - Sometimes when I make a phone call the connection seems to drop and tries to reconnect.  The reconnected line speed is always alot worse.
What could be wrong nowHuh?  This is destroying my mind!
