How many errors is too many?
- Re: How many errors is too many?
08-09-2014 8:31 PM
Evening gents,
Checking over line stats for my FTTC connection and I noticed this;
Total time = 39 min 9 sec
FEC: 99398 10
CRC: 18 2
ES: 6 2
SES: 0 0
UAS: 18 18
LOS: 0 0
LOF: 0 0
Seems like a lot of FEC errors for the uptime, can anyone advise if I should be worried?
DLM has of course applied interleaving: Interleave depth: 1146
Other stats;
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 7765 Kbps, Downstream rate = 45072 Kbps
Path: 0, Upstream rate = 7198 Kbps, Downstream rate = 39088 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB):5.7 6.1
Attn(dB): 0.0 0.0
Pwr(dBm): 12.0 3.1
EDIT: Pulled Attn stats from telnet too
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 4.1 39.5 59.4 N/A 18.1 49.4 0.1
Signal Attenuation(dB): 4.1 39.4 57.2 N/A 18.1 49.4 N/A
SNR Margin(dB): 6.2 6.0 6.3 N/A 5.6 5.8 N/A
TX Power(dBm): -5.2 -3.7 1.2 N/A 10.2 7.4 N/A
FEC: 99398 10
CRC: 18 2
ES: 6 2
SES: 0 0
UAS: 18 18
LOS: 0 0
LOF: 0 0
Other stats;
Status: Showtime
Retrain Reason: 0
Mode: VDSL2 Annex B
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB):5.7 6.1
Attn(dB): 0.0 0.0
Pwr(dBm): 12.0 3.1
Message 1 of 9
(6,006 Views)
8 REPLIES 8
08-09-2014 8:40 PM
see http://www.kitz.co.uk/adsl/linestats_errors.htm
high fec errors with interleaving turned on is normal (it shows it's working apparently).
when i got interleaving turned off the fec errors dropped drastically.
Message 2 of 9
(4,887 Views)
08-09-2014 8:57 PM
Cheers chenks that makes sense then, attenuation looks a bit high too, but I'm sure sure which one I should be looking at or why there is 3...
Message 3 of 9
(4,887 Views)
08-09-2014 9:18 PM
first question... why has DLM activated?
have you had line problems?
Message 4 of 9
(4,887 Views)
08-09-2014 9:21 PM
ES - Errored Seconds
SES - Serious Errored Seconds
These are the two to keep an eye on as DLM is based on them (as well as retrains).
Message 5 of 9
(4,887 Views)
08-09-2014 9:26 PM
Well other than being on an alum line, which is totally killing what sync I can get, OR guy was here he said he was getting 58/20 at the joint box at the end of my street, but max at my property is 43/6, and he said it was due to the alum line which they won't do anything about.
So I guess it's just down to the crappy quality line I'm on DLM seems to be kicking in because of the errors on the line but OR say it's not enough errors to fail / worry about, but if that is the case then why is DLM stepping in....
Cheers Andy I'll keep an eye out for those too
Message 6 of 9
(4,887 Views)
09-09-2014 11:40 AM
Quote DLM seems to be kicking in because of the errors on the line but OR say it's not enough errors to fail / worry about, but if that is the case then why is DLM stepping in....
From the snippet of stats you provided, the line looks fine, but its only been up for 40 mins, so it may not show the full picture. Its not unusual for some lines to be more problematic at certain times of the day particularly evenings when the SNRm begins to drop. As already mentioned by AndyH the ones to worry about are ES & SES. Perhaps grab a copy of DSLstats or HG612 modem_stats (or both!) to monitor whats going on over the course of a day.
Quote but I'm sure sure which one I should be looking at or why there is 3...
Thats because VDSL uses different bands of frequencies. You can see the different frequency bands in my screen grab I'll attach below.
Attenuation is reported separately for each of different bands. Its quite normal (and expected) for the attenuation to increase as the frequency bands get higher.
Message 7 of 9
(4,887 Views)
09-09-2014 12:08 PM
Thanks for the explaination kitz, I'll post full stats tonight when I get home, should have around 24 hours worth by then, I'm actually using DSLstats to pull the stats through telnet it's a very nice application
Message 8 of 9
(4,887 Views)
11-09-2014 8:26 AM
Full stats, anyone see anything wrong? Looks like DLM has reduced the interleaving depth which is good (629 from 1146)
Also looks like DLM resynced me a few hours ago, looks like it's resynced me at a slightly higher down / upstream, which is weirdly higher than the max attainable
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 2
Max: Upstream rate = 7841 Kbps, Downstream rate = 45780 Kbps
Path: 0, Upstream rate = 7882 Kbps, Downstream rate = 39697 Kbps
Mode: VDSL2 Annex B
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Down Up
SNR (dB): 5.8 6.0
Attn(dB): 0.0 0.0
Pwr(dBm): 12.1 3.9
VDSL2 framing
Path 0
B: 63 238
M: 1 1
T: 64 33
R: 16 16
S: 0.0513 0.9641
L: 12478 2116
D: 629 1
I: 80 255
N: 80 255
Counters
Path 0
OHF: 4285971 665969
OHFErr: 21 7
RS: 822906046 1001036
RSCorr: 197120 16
RSUnCorr: 769 0
Path 0
HEC: 221 0
OCD: 0 0
LCD: 0 0
Total Cells: 808017712 0
Data Cells: 127837 0
Drop Cells: 0
Bit Errors: 0 0
ES: 314 74
SES: 10 0
UAS: 58 58
AS: 10595
Path 0
INP: 3.00 0.00
PER: 2.46 15.90
delay: 8.00 0.00
OR: 77.98 20.11
Bitswap: 2392 16
Total time = 1 days 12 hours 31 min 31 sec
FEC: 1038170083 246
CRC: 4693 75
ES: 314 74
SES: 10 0
UAS: 58 58
LOS: 9 0
LOF: 10 0
Latest 15 minutes time = 1 min 31 sec
FEC: 8815 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 30463 4
CRC: 0 3
ES: 0 3
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Latest 1 day time = 12 hours 31 min 31 sec
FEC: 28381701 50
CRC: 2061 14
ES: 30 14
SES: 5 0
UAS: 20 20
LOS: 4 0
LOF: 5 0
Previous 1 day time = 24 hours 0 sec
FEC: 272455669 61
CRC: 2135 15
ES: 101 15
SES: 5 0
UAS: 20 20
LOS: 5 0
LOF: 5 0
Since Link time = 2 hours 56 min 33 sec
FEC: 197120 16
CRC: 21 7
ES: 7 7
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Message 9 of 9
(4,887 Views)
