How long after activation will my FTTC speeds increase?
- How long after activation will my FTTC speeds incr...
- « Previous
- 1
- 2
- Next »
Re: How long after activation will my FTTC speeds increase?
07-11-2012 12:34 PM
That's not possible on FTTC without going down the fault route unfortunately, we can't perform SNR resets either.
I'm asking one of the team to do a couple of line tests to try and see what's going on with your line.
Message 16 of 17
(187 Views)
07-11-2012 2:29 PM
We did some digging and your line is currently performing as it should. The order Chris placed did go through for you, so if your speeds are to increase at all then at least your profile will let you.
If there's anything else then please let us know.
Message 17 of 17
(187 Views)
- « Previous
- 1
- 2
- Next »
